Deza3000 Posted August 9, 2014 Share Posted August 9, 2014 Got this weird boost cut thing thats been happening since last night, ran out of ideas, not sure what to do At WOT, i get the full 1.3-1.5 bars of boost, but once i hit 5-6k revs, the boost drops off completely, and the revs climbs slowly (basically like a n/a), If i shift before i hit 5000 revs, the boost is still good (roughly 1-.1.5 bars), however once i push it to 5000revs, all the boost just drops again, and the car barley accelerates. Once i shift, the car gets back onto boost till i hit 5000revs again. No clue why its happening ==;It happened around 15 minutes after i filled up, so thought maybe it might be a bad batch of fuel??? But then i thought, if thats the case it would be pinging as soon as i hit boost...Boost range: - 1st gear: 1 bar, then drops off at 5000revs to 0 (or below) - 2nd gear: 1.2 bars, then drops off at 5000 revs to 0 or below - 3rd gear WOT (from a 40kph pull) 1.5 bars till i hit 5000 revs then drops off again..... If its hitting high pressure of boost, i have no clue what the problem is anyone got any ideas? Things ive done: - Check MAF sensor cabling - Cleaned MAF sensor with maf sensor cleaner - Checked for boost leaks, tightened all clamps - Chucked in some octane booster - Unplugged battery to reset the ECUThings to note:- Spark plugs are 5000ks new- Evo is tuned for 98 octante fuel- Car runs 100% from 0-4900 revs- No knocking (cant hear anything)- Idle is still smooth- Car starts with easeAny help will be much appreciated Link to comment https://www.sau.com.au/forums/topic/446615-boost-cuts-out-at-5000rpm/ Share on other sites More sharing options...
luke gtr Posted August 9, 2014 Share Posted August 9, 2014 I'd be leaning towards fuel lean out or cas/maf sensors malfunctioning. So, load maxing out or signal going haywire from that point on. It's where I'd start. Link to comment https://www.sau.com.au/forums/topic/446615-boost-cuts-out-at-5000rpm/#findComment-7361725 Share on other sites More sharing options...
luke gtr Posted August 9, 2014 Share Posted August 9, 2014 Oh, of its only since you fueled up, it could be a bad batch. Link to comment https://www.sau.com.au/forums/topic/446615-boost-cuts-out-at-5000rpm/#findComment-7361726 Share on other sites More sharing options...
scotty nm35 Posted August 10, 2014 Share Posted August 10, 2014 Bad fuel isn't going to drop boost. I would suspect the BOV is blowing open, or you have a major boost leak. Pressure testing the intake up to 1.6 bar would be my first check. Link to comment https://www.sau.com.au/forums/topic/446615-boost-cuts-out-at-5000rpm/#findComment-7361958 Share on other sites More sharing options...
Deza3000 Posted August 10, 2014 Author Share Posted August 10, 2014 #@luke gtrYea i was thinking the MAF sensor was playing up, took it out and cleaned it thoroughly, yet to test it out... Also noticed the bolts came off the air box on the maf sensor, so there was a little gap between the airbox and maf.Could it be a fuel pump on its way out by any chance?#@scotty nm35Ill have a look at that today, will do a smoke test to check for leaks...The BOV is pretty new, i doubt its opening early, its a mr edition bov. Link to comment https://www.sau.com.au/forums/topic/446615-boost-cuts-out-at-5000rpm/#findComment-7361980 Share on other sites More sharing options...
Deza3000 Posted August 10, 2014 Author Share Posted August 10, 2014 Update: Just took it for a drive, ran a bit better, but boost is still dropping off at 6000 revs ==; After the boost dropped on 1st @5900ish rpm, i switched to 2nd @ WOT, then as soon as the boost began to drop, i quickly switched to third before the boost completely dropped off, at which point the boost quickly shot up to 1.5bars @4000rpm, It feels like the car really doesnt want to rev past 5000-6000. Feels like the its cutting out boost for a reason. I also have a check engine light now Will need to check the error code tomorrow. Link to comment https://www.sau.com.au/forums/topic/446615-boost-cuts-out-at-5000rpm/#findComment-7362001 Share on other sites More sharing options...
Deza3000 Posted August 10, 2014 Author Share Posted August 10, 2014 This is exactly whats happening! No clue what it is Link to comment https://www.sau.com.au/forums/topic/446615-boost-cuts-out-at-5000rpm/#findComment-7362403 Share on other sites More sharing options...
GH05T Posted August 10, 2014 Share Posted August 10, 2014 Fuel pump making any new noise?i had the same issue on my 32 when my bosch died.if it is dropping rail preassure and leaning out it can do damage quickly. Link to comment https://www.sau.com.au/forums/topic/446615-boost-cuts-out-at-5000rpm/#findComment-7362518 Share on other sites More sharing options...
Deza3000 Posted August 11, 2014 Author Share Posted August 11, 2014 #@GH05TIll check today, it still has the factory fuel pump, maybe it is on its way out. Yea thats true, im a bit worried now, pushing my luck forcing it to boost. Link to comment https://www.sau.com.au/forums/topic/446615-boost-cuts-out-at-5000rpm/#findComment-7362636 Share on other sites More sharing options...
Deza3000 Posted August 19, 2014 Author Share Posted August 19, 2014 Ended up fixing the boost cut finally Turns out there was no cut, it was just the intake pipe collapsing in on boost at high revs, hence why i had no boost. We stretched out the airbox a little to create tension, which resulted in no more collapsing Very hard thing to look for when having boost cuts, cause the intake pipe always rises when you pull over and check, so you'd think its all fine ... Cheers for all the help Link to comment https://www.sau.com.au/forums/topic/446615-boost-cuts-out-at-5000rpm/#findComment-7369228 Share on other sites More sharing options...
Tonba Posted August 26, 2014 Share Posted August 26, 2014 ^ Time to change it out for some hard piping! Link to comment https://www.sau.com.au/forums/topic/446615-boost-cuts-out-at-5000rpm/#findComment-7374316 Share on other sites More sharing options...
luke gtr Posted September 15, 2014 Share Posted September 15, 2014 Good to hear you got it sorted. Link to comment https://www.sau.com.au/forums/topic/446615-boost-cuts-out-at-5000rpm/#findComment-7389577 Share on other sites More sharing options...
