My apologies if this has been discussed already, I had a look and whilst I did find some info on vct I didn't find what I was looking for,
What are the options for running an RB25DET VCT without the cluster? Apparently the only way is with an aftermarket ecu?
Thanks
https://www.sau.com.au/forums/topic/446630-rb25det-vct/
You mean the speedo cluster? It is not required for the operation of VCT.
Also 'plug-in' aftermarket ECU's will retain the VCT funciton, but if you use a NIStune ECU you need an RB20 or Z32 ECU and a window switch to control VCT.
https://www.sau.com.au/forums/topic/446630-rb25det-vct/#findComment-7361910
Not true. Nissan ECU requires functioning VSS in order to make VCT work. Therefore cluster is required, seeing as the cluster is the source of the VSS.
It has been done before by tucking a speedo head up behind the dash where a cluster is not otherwise desired in the car.
https://www.sau.com.au/forums/topic/446630-rb25det-vct/#findComment-7361923
I say it again - and even the Nistune docmentation says it - the std ECU requires functioning VSS to activate VCT. The threshold speed can be set to zero (in which case it possibly will work without functioning VSS). If Trent tuned it then it was almost certainly set to need zero speed to trigger. But there is another threshold which is minimum TP (load) which is about 48 on standard maps. That is why you only see VCT activate once you get to a certain speed/load. It's not road speed, it's not rpm, it's pure load. Then it turns off at the turn off rpm (5400 or whatever it is).
But here's the thing. I also have RB25 box with Navara sender in R32. The cable drive makes the speedo head turn. The speedo head generates the ECU's required speed signal. it is quite possible for the speedo head to be broken in a way that the needle won't work but the internals and the VSS are actualy working, so maybe that was the case.
I for one, have seen my VCT not work when my VSS wasn't.
https://www.sau.com.au/forums/topic/446630-rb25det-vct/#findComment-7361968
I always assumed it worked via engine load not VSS, but obviously it uses a combination of that as you said. I did wonder if the speedo cable was able to drive a tacho generator and therefore the ECU was still receiving a VSS input, but i honestly wasn't sure.
https://www.sau.com.au/forums/topic/446630-rb25det-vct/#findComment-7362000
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
