Dye *should* work on the _cloth_ but not on the hard vinyl. That said, it's a mixture of both of these things.
You probably have a sedan, and want a coupe as the coupe got all the black interior and the sedan is silver. I was planning on just taking the lot to a trimmer as you've noticed it's a mix of cloth, hard plastic, and bits of metal that need to change colour so I wager you will need all sorts of different, complimentary skills to actually make it work.
Man, you guys are like an all knowing encyclopedia.. how do you guys know how to fix everything??
but thanks. i will try to trace this wiring today. What is this globe thing you are referring too? Globe Power Supply? Are you referring to the light bulb?
Vinyl paint always ends up coming off interior trim and looking like arse.
For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
