Hi all,
I just wanted to post up my positive experience (so far) with NPC Performance Clutch.
The Xtreme cushion button clutch in my R33 failed after a few years and needed to be replaced.
I contacted Xtreme Clutch to discuss clutch options and information about the failure and got a whole lot of NOTHING! I spoke to a salesperson on the phone who seemed far too busy doing something else to listen to my questions, frequently saying "huh?" or "what?" and forcing me to repeat myself. He gave me less information than I could find on my own search of their website. Shame.
I then followed up with an email enquiry including photos of the worn parts and asking for some advice about what to spend my money on. I still haven't received a reply.
In stark contrast, I contacted NPC clutch. I received an email back from Doug very quickly, which started the ball rolling. Doug answered all of my questions and based on the times of some of the emails- he works very late!
Needless to say I spend my hard-earned on an NPC 10" carbotic clutch kit and the kit turned up 2 days after I ordered it! Much fast!
It went in a couple of weeks ago without a hitch and is almost bedded in ready for Bathurst hillclimb later in the month.
The clutch has a nice light pedal feel and bites solidly without being overly aggressive and Im looking forward to giving it hell.
So, if you are in the market for a new clutch, I think you can't go past NPC.
If you want to be ignored, go to Xtreme!
https://www.sau.com.au/forums/topic/446705-npc-performance-clutches-thumbs-up/
had a 10" NPC clutch in my car for years now. I had it rebuilt when I changed my engine, more out of conenience then anything. Clutch and pressure plate still looked fine, I run the NPC lightweight flywheel as well. Very happy with it
How long should one of these clutches last you, assume city and street driving, little to no clutch drops. My carbon clutch which I had made about 2 - 3 years ago now is still holding up but the grabbing point seems to have shifted so it might be time for me to consider a new clutch. How much are these and what power can they hold?
I got mine in 2010 I think. Rebuilt it last year but it probably didn't need it mine is daily driven. Just don't slip the clutch too much and it should be fine. The NPC flywheel helps as well because it has cooling channels
yeah its a ripper clutch...better than any exedy I've used...after a couple thousand kms it softens up really nice as well..
the guy who bought my car had a stuffed knee from a motorbike accident and couldn't believe how easy it was to use..
next time your cruising at 100, drop it back to third, give it a 6000rpm+ and drop it...you'll feel it just bites.... :rofl:
I've been running NPC7333HD-10" on my R34 GTT since my manual conversion, it's a great clutch with a good feel and not heavy at all. I spoke with NPC prior to purchasing it, great service too.
Btw this clutch is the same as Exedy NSK-7333HD. Mine even had part of the packaging with Exedy logos, though the clutch itself was in NPC shrink wrap.
Just call Jim and tell him your upgrading to 400Kw, he may even be able to rebuild and upgrade your old one to do it, he has no issues build clutches to handle far more power than that if needed.
  On 24/08/2014 at 11:08 AM, WARLORD said:
just wondering what kind of power are some of you guys putting down with a npc clutch im looking for a change from my jim berry clutch need something to hold 400kw
Im putting 350kw with it tried it first time last weekend no bed in just clutch kiking from first lap and its a great clutch, others have been running 400kw with it so should be alright for you.
Also you can tell Doug to trick up the pressure plate to clamp more or less.
Of course when you ask for more clamp the clutch is super hard to drive (like when I had a NPC). Hill starts resulted in baked tyres lol
However if you reduce the clamp the clutch is quite friendly and as soft as a stock clutch (pedal effort wise)
  • 6 months later...
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
