Just got my NPC Organic 10" installed and the pedal feels like an N15 pulsar's - light as. Still wearing it in but so far it feels really grippy and easy to use. A lot better than the Exedy that came out, which was slipping at 250rwkw and felt like doing a 40kg left leg press.
  • Like 1
My NPC Organic 10" is a rebadged Exedy unit (or vice versa), even the part numbers match. So my assumption is that a new Exedy would be just as good as a new NPC with these specs :)
nope, NPC uses Exedy parts - however their clutches are modified with different friction material and their pressure plates are modified in house.
A normal Sports Organic or Ceramic (silver pressure plate) clamps less than a NPC and the pedal effort required to disengage the clutch is heaps more.
Doug from NPC (I believe through rumours) used to work at Exedy and took his knowledge to NPC.
  • Like 4
  • 5 weeks later...
Good clutch worked well but doesnt last too long under heavy abuse compared to my previous exedy HHHDB but trade off is its easy on the box lasted 11 drift events roughly 1 year HHHDB lasted 2.5years and still was working when removed going to move up to the twin plate super coppermix competition now.
Same, mine has had over 80+ rwd launches
1 Very very bad launch at the drags which was rode mistakenly.
( had to let it cool down after that )
Many many track days, 2 1000 meter runway events
going on 2 years now i think from memory
My last 3 clutches before that where both Exedy Organic's HD
1 did ok...but that was around 300 hp.
1 fried it self after a couple of months
The other literally snapped the pressure plate.
My mate also same clutch, broke 2 of them, 1 was the same Pressure plate snap.
Exedy where awful when it came to asking wtf happened when it was sent back.
Got " you change gears to fast " ......really....
Never buying exedy again.
  • Like 1
Yeah i guess difference is in my use its cinstntly clutch kick 3rd 4th gear consecutively as appose to drag doing 1 launch then it has time recover and cooldown or circuit driving its proper shifting. But like i said definately good clutch in terms of what it can take for such a low camping force and does save boxes.
The only exedy that is good is the hhhdb clutch disc is identical to the npc with only diff having a massive 1500n clamping load pressure plate lol but rest of the mild exedy clutches dont take much abuse.
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
