Just got my NPC Organic 10" installed and the pedal feels like an N15 pulsar's - light as. Still wearing it in but so far it feels really grippy and easy to use. A lot better than the Exedy that came out, which was slipping at 250rwkw and felt like doing a 40kg left leg press.
  • Like 1
My NPC Organic 10" is a rebadged Exedy unit (or vice versa), even the part numbers match. So my assumption is that a new Exedy would be just as good as a new NPC with these specs :)
nope, NPC uses Exedy parts - however their clutches are modified with different friction material and their pressure plates are modified in house.
A normal Sports Organic or Ceramic (silver pressure plate) clamps less than a NPC and the pedal effort required to disengage the clutch is heaps more.
Doug from NPC (I believe through rumours) used to work at Exedy and took his knowledge to NPC.
  • Like 4
  • 5 weeks later...
Good clutch worked well but doesnt last too long under heavy abuse compared to my previous exedy HHHDB but trade off is its easy on the box lasted 11 drift events roughly 1 year HHHDB lasted 2.5years and still was working when removed going to move up to the twin plate super coppermix competition now.
Same, mine has had over 80+ rwd launches
1 Very very bad launch at the drags which was rode mistakenly.
( had to let it cool down after that )
Many many track days, 2 1000 meter runway events
going on 2 years now i think from memory
My last 3 clutches before that where both Exedy Organic's HD
1 did ok...but that was around 300 hp.
1 fried it self after a couple of months
The other literally snapped the pressure plate.
My mate also same clutch, broke 2 of them, 1 was the same Pressure plate snap.
Exedy where awful when it came to asking wtf happened when it was sent back.
Got " you change gears to fast " ......really....
Never buying exedy again.
  • Like 1
Yeah i guess difference is in my use its cinstntly clutch kick 3rd 4th gear consecutively as appose to drag doing 1 launch then it has time recover and cooldown or circuit driving its proper shifting. But like i said definately good clutch in terms of what it can take for such a low camping force and does save boxes.
The only exedy that is good is the hhhdb clutch disc is identical to the npc with only diff having a massive 1500n clamping load pressure plate lol but rest of the mild exedy clutches dont take much abuse.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
