I am also running a NPC clutch but just the heavy duty organic and it's holding 250rwkw fine and the pedal feel is light and good for the street. There service is also awesome.
Edited by DoseVader
spoke with Doug @ NPC, he recommended the 10" organic like everyone else has, i assume its the same carbotic plate and will hold 300rwkw comfortably.
Thanks guys!
Organic and carbotic are different.
Thanks guys!
Same clutch in the stagea (organic not carbotic) very nice to use.
Same here, been running NPC 10"-HD organic with a manual conversion for about a year at 275rwkw, holding up well, including 40 laps of Sandown on a track day.
+1 for good service, too.
I installed a 10inch carbotic clutch with a lighter flywheel many months ago and took it out for its first drive last weekend! Wow pretty much drives like a stock clutch alot better than the shitty xtreame shuttery POS. Could not be happier with the product so far.
Can't wait to get a full tune to she how it all goes together!
  • 4 weeks later...
called npc up today and they quoted 2500 for their twin plate +$500 for the pull-push converter. based on what they had said over the phone they didn't think the single could handle 350kwatw
thinking of the Nismo twinplate but need one this week...
  • Like 1
Nah it just holds the intermediate plate and cover (pressure plate) and stops them from spinning relative to the engine. Probably better to google image it because i'm not explaining it well.
If NPC say what they sold you is good for 400-450, then i'd be confident it is.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
