hey guys so i need some expert advise on the whole rb25det s1 and s2 loom and engine differences.
current set up is a rb25de(+)t engine in a r32 4 door running the stock rb20det loom/ and i assume rb20det computer?
this rb25de+t is a vct but vct isn't plugged in cause its a rb20det loom.
Question 1.so i am currently getting a rb25det series 2 engine built and my question is do i need a complete rb25det series 2 loom to run this engine.
or can i get it to run on my current loom?
Question 2. would it work if i used s1 coilpacks on the s2 engine?
Question 3. what are the differences between a series 1 and 2?
Question 4. which is better?
cheers guys.
https://www.sau.com.au/forums/topic/446739-rb25det-s1-and-s2-loom-questions/
So let me just get this straight. You've got an R33 RB25de engine (with VCT disabled) in an R32 with an rb20det loom and which Ecu? Best checking to be sure mate.
You shouldn't have any issues really other than having to wire up a window switch for VCT. This is majorly important by the way, the car will be 100x nicer to drive with VCT functioning.
About Coilpacks I'm not 100% sure someone else can weigh in.
Good luck
Edit: the difference in s1 and s2 rb25dets is I believe the long nose crank which engages the oil pump fully. Not a deal breaker but if you've got the s1 motor without a crank collar then keep off the limiter
Edited by Blackkers
  • 5 months later...
Sorry to bring up an old thread but id rather not start a new one. I was given a RB25 loom by a mate to help with a budget 25/30 build and it didn't come with the "external" looms (injector, gearbox and coil pack. not sure if there's another im missing). Are there any ways to tell wether its a S1or2 from just the basic loom? I assume from what has been said above it doesnt actually matter tho. like if i get S1 coils i just have to get the IB and itll plug into the same plug that the S2 coilpack loom would plug into (obviously directly due to not having the external IB). i may not have worded that very well haha so let me know if i need to clear anything up.
cheers
I wouldn't count on that. I don't think the plugs are the same. The ignition looms ARE different, not just interchangeable parts.
    • Also did some work to the shed and a massive clean out of stuff. It's now got a small fab/dirty room and has helped keep shed cleaner. Built some new work benches and re organised things also got a TV out there so good having something playing while working on the cars. Got a pedestal drill and linisher off a mate that need to pick up too.
    • First thought, have your current injectors flow tested. If they test fine, keep the diagnostics going. It's not the injectors. If the injectors are the issue, find some new or used (cleaned and flow tested) injectors.  While I really love a good excuse to get a modern ECU installed, just needing new injectors probably isn't a good enough reason to do so.
    • A bit from column A, B and C. Mainly C   Update time, after deciding it was time to tick off a bucket list goal I finished up full time at MSR and have gotten back behind the wheel and making progress on the S15. Goal has been to drive Bathurst at an event and I have had my entry accepted for Challenge Bathurst in November. Since I don't want to go unprepared I need it running to test and get comfortable.  Been chipping away at it and started by stripping inside, getting it all cleaned and sealing some holes up. With stripping inside I removed the whole wiring loom and found a few surprises.......... its pretty butchered and shit branching and I'm not a fan of the haltech fuse boxes so it's all out and trying to come up with a plan to rewire it all either new fuse/relay box or pdm.  I haven't been happy with how I did the intercooler mounting and been wanting to tuck it up under rad support. O e issue with that is headlights will need a decent trim or get replacement covers. Took the time to mount it with some stand off's and new hardware. Stands are some m8 button bolts, washer, aluminium tube and factory radiator top mount rubbers. It's nice and solid also stiffens rad support which still requires some trimming. Bonus of factory rad mounting is used all factory hoses just need to weld a pressure cap to radiator now. Got sensor block and fuel filter mounted. Plan today is to get vac lines all sorted with push in nylon tube and design oil cooler mounting solution.  Been driving BRZ a heap and went out to Morgan Park for time attack and went pretty well for a wet day. https://youtu.be/gAlQgcQpWj4?si=kojOAOjhhX_X3AXR Getting pretty comfortable in it now and want to do a few more bits to it but restraining myself as don't need 2 race cars at the moment.
    • @sunsetR33 There is obviously a huge culture gap here. There is nothing in place like this in Australia, where if you fit a Mines branded pipe and later replace it with a Jun branded pipe, both pipes are essentially identical - BAM - huge penalties! Where is the Mines pipe?? You can't have a Jun pipe when you said you had a Mines pipe!  Makes no sense to me. Surely makes no sense to anyone else here either.  I'm sure a lot of us would agree that our registration/engineering system is pretty stupid at times, but it's not that stupid.  *** More serious question here. If you replace a factory rubber hose with a silicone hose, is the car illegally on the road now? Does it become legal if you have certification of what brand the silicone hose is? Then would it become illegal again if you replaced that silicone hose with a difference brand of silicone hose? And then would it become legal again if you had certification of the new brand of silicone hose?  I really want to know that answer to that question.
    • Good you making progress with this rig. Aluminium welding is painful to learn, have you got a pedal as I found it so much easier with one. If that's the AMG I think it is, you would working with Benny?
