R33 GTR for under $40,000.... Can it be done?
  • Replies 45
Not likely that i will be asking to run 95 octane in my car when u consider I pay near $8.00 per liter for fuel for my race car. The only reason I have to budget for my car is because I have to look at insurance costs aswell... Plus this is only a road car so I dont need anything that will be ultra fast.... After all my Formula 3 does 0-100kmh in 2.8 seconds so I dont quite think a GTR will supply me with the same thrill in terms of speed
Do you like the R32 GTR? Your $35k would get a very, very, very nice GTR.. and depending on personal opinion (and it's a close battle) I still think that the R32 is a better buy and better looking, between 32 and 33. R34 is king obviously. (you have to spend more bucks to get the R33 looking sexy)
You could even save some of your cash and spend - $28k - $30k (still getting a top R32) keep some spare for a nice set of rims, performance upg's or just save it!
Guest two.06l
i agree r33 gtrs look like fat camrys
cant go wrong .. the r33gtr .. is the fatter more weighted r32 .. in my eye ... even on stock boost and a really good cooler .. they just pull so so much torque... if u get em tuned right .. i've seen and been in a r33 gtrand when dyno'd and tuned was pulling 1234nm of torque and 184kw at the wheels .. there just rapid ...more weight isn;t really a bad thing in comparison to the r32 gtr ...u gotta get the power and torque down somehow
33 GTR's are the way to go... you get performance, supercar status and looks ain't that bad - i still get plenty of looks. If anyone is hung up about looks then spend the same amount on an r34gtt - but i tell you from experience my swap to a series 3 GTR is well worth it.
I havent seen or know the car but a melbourne user calvantys is selling an r33 gtr for $38k on the forums at present. Doesn't appear to be heavily modded, might be worth a look.
Haevy mod ....... well you guys going to be supprice if you have a look at my car, Yes i have listed alot of aftermarket parts but most of them is not even install on my car yet. Example my gear box haven been open before, look at the screw and you will know but i have a twin plate clucth.;)
Parts that are not install on my car but goes in a packet of my car is
Nismo Injector
Twin T618Z turbo (does not include in the packet)
Trust Piston (does not include in the packet)
Oil cooler
Power FC
Boost controller
and list goes on but my car is still stock on exhaust and Filter are currenly on else standard.
Just be careful even if you manage to pick up a GT-R for under 40k, it still has the running costs of a 130k motor car.
I have seen quite a few GT-R's under 40k. Majority of them have had some sort of accident history.
The servicing costs isn't bad but its more if something goes wrong. Engine Rebuilds, Gearboxes.. yikes!!.
Make sure you get it checked out and even go further by getting a 2nd opinion.
Try and get a GT-R where the Instrument cluster is original. All Clusters that have been modified are most likely non-original kms.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
