First post so take it easy.
I bought the mrs a series 2 33 which was pretty stock apart from slammed suspension and pod filter.
All i have done so far is a front mount intercooler.
i am getting a boost controller in the next few weeks.
What other reasonably cheap mods can i do to give it a bit more go?
https://www.sau.com.au/forums/topic/446752-r33-s2/
In a nutshell (and I'm assuming it's a GTST, not a GTR, but it's worth you mentioning these things):
Forget about the boost controller at this stage
Do a full service if you don't know the status - oil, oil filter, air filter, coolant, plugs, check wiring
Think about a timing belt replacement if you don't know how old it is
If you do the timing belt, also replace the water pump, crank & cam seals, tensioner & idler pulleys
Test for boost leaks
New fuel pump for safety - if it's still got the original one it's around 20 years old
3" Turbo back exhaust, including high-flow cat
Z32 (300ZX) or R32 ECU plus a Nistune daughter board - this will allow a tuner to modify the factory tune
R32 Wastegate actuator (10 psi vs 5psi stock)
Get it tuned by someone who knows what they are doing - 210+ RWKW and a different car to drive
https://www.sau.com.au/forums/topic/446752-r33-s2/#findComment-7364960
Cheers for that
It does have a 3" exhaust
front mount
and timing water pump etc have been done 60000km ago.
I was suprised drives better than a few cars i have driven lately that are less than 5 years old.
ECU is in the works as well as a tune.
The 32 wastegate actuator i take it is a stock item on the r32 and pretty easy to come by.
It is actually sounding quite cheap to do what i need.
Suspension will be the hard bit as at the moment its a bit to low and before to long i can see me or her leaving the front bar on a speed bump or something
https://www.sau.com.au/forums/topic/446752-r33-s2/#findComment-7364989
I would strongly suggest avoiding Nistune with an R33. There are numerous other ECU's that will plug and play such as PoweFC (older tech) through to Adaptronic, Haltech, Link.
I would consider carefully what you want from the car as careful selection of parts in the first place will save you thousands. If you want more than 200rwkw then you are into the world of aftermarket turbos and new injectors. Each change will require more tuning so take your time to figure out realistically how you will use the car and how much power is needed to achieve it.
https://www.sau.com.au/forums/topic/446752-r33-s2/#findComment-7365015
Cheers for that
front mount
Is this going on the timing belt change info from its Japan days or has it been done in Australia? (kms get wound off in the importation process).
Is the 3" exhaust from the turbo back or just the cat convertor back? also does it have a higher flow cat?
https://www.sau.com.au/forums/topic/446752-r33-s2/#findComment-7365075
If it's going to be a daily & you you don't want huge power I would stick with a Nistune. Others will tell you different, but a Nistune will do the job for you, as it does for me.
Yes - 32 wastegate actuater is stock on an R32, and is a direct replacement on an RB25Det. If you want more than 10psi you can leave the current boost solenoid installed, either in stock wiring or hot-wired to be always on higher boost. Note I haven't tried this - our solenoid has been removed.
https://www.sau.com.au/forums/topic/446752-r33-s2/#findComment-7365195
There's a couple of points relating to the above post that need clarifying though.
If you use an R32 ECU to do Nistune then you don't get working VCT unless you install a separate way to switch it in and out. if you use a Z32 ECU for Nistune then a few other things don't work as well as they should. You need a decent tuner who has done these R33 Nistune jobs before to make it less painful.
If you use an R32 ECU then the stock boost solenoid cannot be controlled, because the R32 doesn't even have one.
R32 10psi actuators are not exactly lying around in piles, because every stock turbo R33 owner wants one.
https://www.sau.com.au/forums/topic/446752-r33-s2/#findComment-7365201
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
