spanner? you need a 1/4" socket set.. spanner will hit the fan and/or the ancillaries belts I think.. never tried loosening the CAS bolts with a spanner, curious now if it fits lol.. always have used a socket
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7366069
All done and didnt break the circlip. Im not a mechanics butthole but all went well and pretty straight forward. Ended up with 11-12lb boost heaps better to drive.
Next job is the new heater core i picked up. Not looking forward to that.
Then in 2 weeks going in for a tune. once i pick up the z32 ecu.
  • Like 1
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7372687
  • 1 month later...
Ok bit of progress and wondering where to go next. Got the ecu and nisstune and tuned and what a difference got 207 kw at the wheels which i thought was pretty good off a stock turbo, motor, injectors and fuel pump. Now what next to do. Im thinking afm, injectors and fuel pump. No idea on what type yet some research will have to happen
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398688
to be honest mate, you can't go much further without spending heaps and losing response anyway.
But if you want more power and I assume you do, next job would be new turbo. The stock turbo will die an early death if you push it any harder
supporting mods include but are not limited to:
-fuel pump Walbro GSS341/342 for petrol or F90000267 for E85
-Z32 AFM
-Injectors (if you want more than ~245rwkw on petrol or if you want E85 at all)
-coilpacks/clutch if need be.
Don't forget to run a direct battery feed for a new fuel pump regardless of which model you use.
Good luck
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398705
would i be able to reach 250kw with the stock turbo.
Absolutely not. Maybe on E85 you could get close, but it will be a bad thing to do. Turbo maxes out at less than this in terms of air flow, and when you push it that hard you are risking it flying to pieces (fragile ceramic turbine remember!!!!!!!!)
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398746
Cheers mate will probably go high flow turbo so boost comes on early unless there is an after market turbo that can do this and handle high teens off boost. Will get the fuel pump probably this week if i have time and then in a few months the rest and possible turbo
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398759
Look at http://www.sau.com.au/forums/topic/448435-factory-response-aftermarket-turbo-rb25/?view=findpost&p=7394103 to see what an HG highflow can do for you even with stock injectors. The ability to wind the boost up to values that will destroy the stocker is not to be scoffed at.
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398771
