spanner? you need a 1/4" socket set.. spanner will hit the fan and/or the ancillaries belts I think.. never tried loosening the CAS bolts with a spanner, curious now if it fits lol.. always have used a socket
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7366069
All done and didnt break the circlip. Im not a mechanics butthole but all went well and pretty straight forward. Ended up with 11-12lb boost heaps better to drive.
Next job is the new heater core i picked up. Not looking forward to that.
Then in 2 weeks going in for a tune. once i pick up the z32 ecu.
  • Like 1
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7372687
  • 1 month later...
Ok bit of progress and wondering where to go next. Got the ecu and nisstune and tuned and what a difference got 207 kw at the wheels which i thought was pretty good off a stock turbo, motor, injectors and fuel pump. Now what next to do. Im thinking afm, injectors and fuel pump. No idea on what type yet some research will have to happen
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398688
to be honest mate, you can't go much further without spending heaps and losing response anyway.
But if you want more power and I assume you do, next job would be new turbo. The stock turbo will die an early death if you push it any harder
supporting mods include but are not limited to:
-fuel pump Walbro GSS341/342 for petrol or F90000267 for E85
-Z32 AFM
-Injectors (if you want more than ~245rwkw on petrol or if you want E85 at all)
-coilpacks/clutch if need be.
Don't forget to run a direct battery feed for a new fuel pump regardless of which model you use.
Good luck
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398705
would i be able to reach 250kw with the stock turbo.
Absolutely not. Maybe on E85 you could get close, but it will be a bad thing to do. Turbo maxes out at less than this in terms of air flow, and when you push it that hard you are risking it flying to pieces (fragile ceramic turbine remember!!!!!!!!)
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398746
Cheers mate will probably go high flow turbo so boost comes on early unless there is an after market turbo that can do this and handle high teens off boost. Will get the fuel pump probably this week if i have time and then in a few months the rest and possible turbo
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398759
Look at http://www.sau.com.au/forums/topic/448435-factory-response-aftermarket-turbo-rb25/?view=findpost&p=7394103 to see what an HG highflow can do for you even with stock injectors. The ability to wind the boost up to values that will destroy the stocker is not to be scoffed at.
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398771
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
