Swirl Pots
66yostagea
 Share
As you may know I have the "Gurgles" in the RS4. Probably due to the way the Skylines members instructions said to install the FFP.
Came across info on a "Swirl Pot and Header Tank" Has anyone used one, or knows anything about it?
Edited by 66yostagea
Obviously, the swirl pot must be mounted above the head height of the rest of the cooling system to work properly, but the theory is; the coolant draws through the system using convection.
The leg connected to the bottom rad hose draws coolant in and down as it is colder, and this allows a constant inflow from the hot side of the cooling system.
Any bubbles throughout the system will obviously migrate to the highest point over time, and this can then be purged completely and will the draw coolant with no air from the overflow tank; thus eliminating any air pockets within the system.
Convection is a surprisingly effective way to move hot liquids; early cooling systems that didn't have a water pump used convection to provide fluid flow through the system.
As time went by more effective means of cooling were required as more power (thermal energy) was generated and space constraints for radiators and water volume were reduced.
You see many high powered engines (especially RB's) using swirl pots as they generate enough localised heat to flash boil pockets of water within the head; this then causes cavitation if it isn't released.
An inline swirl chamber is far more effective as it separates the bubbles directly out of the coolant flow from the engine, as opposed to just the bleed points. Obviously this system would still require the use of a header or swirl tank above the level of the head height of the cooling system.
Hope this clears things up.
Seems like alot of stuffing around for what is essentially an unrequired mod (ffp)
Losing torque, and impacting negatively on the cooling system just to get some tidier pipework.
  • Like 2
I am getting to the point where, after I finish the Dayz rebuild, I will take off the FFP and put the piping back to stock. It is pointless having an RS4 that has to tippy toe around.
I realise its hard to photograph the underside of the ffp but if you can put up some pics I will compare it to mine (do you have a Greddy copy?) as I am not having any such problems.
I said it before, it was a Christmas present from my son. It came with an Xforce cat
  • Like 1
  • 3 weeks later...
 Share
    • 5 minute job, at a NRMA branch. Not sure how easy it is in NZ for @R3N3
    • Thanks. I was looking to book a tour to daikoku, not sure if anyone has done that before?
    • Well if you look at the compressor map I would say that the g35-900 will do it alot easier and be in a better efficiency range. In regard to throttle response and boost threshold, I doubt you would feel the difference but obviously there will be one.
    • Unfortunately we ended up not quite getting to where I wanted alignment wise. Ideally I was targeting -3.5 to -3.8 camber as a good compromise for drift/grip/street. But due to the combination of custom configuration custom parts and the relationship between caster and camber (as you reduce camber you also reduce caster) on R32 we ended up at: Front Camber -4.5° Caster +7° Toe -4mm toe out each side. -8mm total Rear Camber -1.5° Toe 2mm in each side 4mm total in Perfect for drift but will be a touch too much camber for circuit. Thankfully the arms being modular means a change to one simple bracket will give me the adjustment I need to get to -3.7° camber and keep the caster at 7°.
    • Thanks @waxracing Turns out G30-770 T4 twin scroll 1.06a/r isn't available for reverse rotation. So really, the only real question is, will the G30-770 v-band .83a/r produce 500whp on pump gas? If it's unlikely, should I go to G30-770 1.01a/r, G30-900 .83a/r or G35-900 .83a/r? Or any other combination...
