As you may know I have the "Gurgles" in the RS4. Probably due to the way the Skylines members instructions said to install the FFP.
Came across info on a "Swirl Pot and Header Tank" Has anyone used one, or knows anything about it?
Edited by 66yostagea
https://www.sau.com.au/forums/topic/446753-swirl-pots/
Obviously, the swirl pot must be mounted above the head height of the rest of the cooling system to work properly, but the theory is; the coolant draws through the system using convection.
The leg connected to the bottom rad hose draws coolant in and down as it is colder, and this allows a constant inflow from the hot side of the cooling system.
Any bubbles throughout the system will obviously migrate to the highest point over time, and this can then be purged completely and will the draw coolant with no air from the overflow tank; thus eliminating any air pockets within the system.
Convection is a surprisingly effective way to move hot liquids; early cooling systems that didn't have a water pump used convection to provide fluid flow through the system.
As time went by more effective means of cooling were required as more power (thermal energy) was generated and space constraints for radiators and water volume were reduced.
You see many high powered engines (especially RB's) using swirl pots as they generate enough localised heat to flash boil pockets of water within the head; this then causes cavitation if it isn't released.
An inline swirl chamber is far more effective as it separates the bubbles directly out of the coolant flow from the engine, as opposed to just the bleed points. Obviously this system would still require the use of a header or swirl tank above the level of the head height of the cooling system.
Hope this clears things up.
https://www.sau.com.au/forums/topic/446753-swirl-pots/#findComment-7364465
I am getting to the point where, after I finish the Dayz rebuild, I will take off the FFP and put the piping back to stock. It is pointless having an RS4 that has to tippy toe around.
https://www.sau.com.au/forums/topic/446753-swirl-pots/#findComment-7364619
I realise its hard to photograph the underside of the ffp but if you can put up some pics I will compare it to mine (do you have a Greddy copy?) as I am not having any such problems.
https://www.sau.com.au/forums/topic/446753-swirl-pots/#findComment-7364894
Seems like alot of stuffing around for what is essentially an unrequired mod (ffp)
Losing torque, and impacting negatively on the cooling system just to get some tidier pipework.
I said it before, it was a Christmas present from my son. It came with an Xforce cat
  • Like 1
https://www.sau.com.au/forums/topic/446753-swirl-pots/#findComment-7376859
  • 3 weeks later...
https://www.sau.com.au/forums/topic/446753-swirl-pots/#findComment-7388808
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
