  • Replies 83
What a top day guys, will look forward to the viewing night at Dundans to check out all the days bloopers and random shanigans
And congrats to Kel for picking up the dented VW hubcap award for the most flag fatalities :)
hahaha that was a great day out, shame about the weather but it was perfect for bad behaviour.
This is the only footage I've ripped so far:
http://www.hgeconsulting.com.au/whataboutt...ebrakestosh.wmv 3.8mb
Looks like everyone had a heap of fun :)
2 words about the datto...... F**KING HANDFUL
took me a bit to get used to it as it handles like a boat but after a little bit of advise from a friendly rotary driver I was starting to get the hang of slinging it sideways....
As Duncan has already said it needs a few things:
1. STIFF AND LOW suspension
2. Smaller steering wheel
3. MUCH tighter handbrake
4. New Seat
5. New Engine and 5 speed gearbox (pending compression test)
6. New Radiator
All in all I was fairly happy with the way it went throughout the day, the locked diff certainly provided some entertainment for the crowd watching at times :P
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
