most comments/threads say stock is fine for about 500kw, how are they making more?
It is just a manifold, it will make more power with it but won't do so efficiently.
A larger volume plenum is better as it allows the air inside to distribute itself better to each of the ports. Are you still using the individual throttle bodies?
Greddy is a nice cheap upgrade as it is over 5L which is closer to two times engine displacement.
larger volume plenum = lower velocity air for the same given airflow.
at low rpm that translates to less torque, at high RPM/boost that translates to more airflow.
around the 600rwkw mark I assume you don't care much for low end drivability so go for it. I assume it would help the top end slightly at a slight cost of bottom end torque.
Whether or not it's worth the cost is, as always, up to you
If I'm wrong someone please weigh in
I'll weigh in just a little bit. Most of what you wrote is right, just the bit about reduced torque is worth a bit more thought.
The velocity of the air in the plenum is not much of an issue for torque. What matters for torque is velocity in the runners and ports. That is what drives cylinder fill. The plenum is exactly what its name implies - it is a plenum. It is just a volume. Its purpose is to provide a volume from which all the cylinders can draw, hopefully evenly, with the air having come from a common source beforehand. In this case the common source is the air flow metering (if present) and the turbo(s). It is of course perfectly possible to run an RB26 or any other ITB engine with no plenum at all. Of course you have to go without the turbo charging, and you have to do something other than AFM sensing, but you get the idea.
Anyway, given the above, a big plenum shouldn't hurt torque. What it does hurt is throttle response. A bigger volume that needs to be filled up with boost. Luckily though, if you keep the ITBs, then the penalty on throttle response is merely that required to fill the plenum with boost, not that caused by having a plenum at much lower pressure with a throttle at its inlet, which can be worse (bcause you get both effects at once, instead of just one of them).
The rule of thumb that the plenum should be about double the engine volume is not based on any real science. it just kind of works because once the plenum gets to about that size then it tends to be big enough to work to distribute the air fairly evenly to the cylinders without too much localised high velocity regions (near cylinder #1 for example). if you stick with a small plenum and jam a massive amount of air flow through it, the velocities go up and any problems with distribution just get worse. Bigger is better for high power but not quite as good for throttle response, as noted above.
  • Like 3
This bloke! Good post.
Thanks for the more detailed response!
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
