Hey everyone
I've noticed there isn't much into on fuel pumps etc when searching the forum so I thought I would add some of my own stuff.
So here is a bit of info that I can give. I am also after a few other opinions.
I'm a Nismo man, I have never had any issues with the Nismo 275lph pump that they make a drop in for most Skylines. Problem is, these don't have official E85 support.
I've been looking at these pumps:
1. Walbro 400lph E85 Pump (Apparently some issues with priming?)
2. Deatschworks 320LPH Version 2 E85 Pump
3. Bosch 044
4. Nismo 275lph Straight drop in
Okay... so there are other catches... like factory wiring. Does anyone have an idea on what sort of amperage the factory wiring can handle? I've been looking at flow charts and comparing amp draw with PSI etc.
Here are some flow charts.
Walbro 400lph
Random Pumps
Deatschworks 320LPH Version 2 again
The FLow charts are definitely interesting.
My intentions are:
Replace the factory fuel pump in my BNR34 with a decent pump that will do 400awkw, and from there, when its time to go for more power, I will add an aftermarket industries surge tank, and use the twin Holley Dominator 1400 pumps to feed my injectors. (ID 1300cc Stainless)
Currently installing 2 x HKS 2530s and supporting mods.
Your input would be appreciated.
The Mafia
https://www.sau.com.au/forums/topic/446806-the-fuel-pump-thread/
I run twin Walbro 255's, less current draw than the e85 pump and more flow. Still I had to upgrade the tank lid for the extra current draw and flow requirements. I ran twin feed lines, one to each rail on the VQ.
For 400+kw intank, single pump, the e85 Walbro is probably your best option, but you may have to re-pin the plug at a minimum. I have had issues with the DW pumps on ethanol, and will never use one again.
Hey mate
Can you go into more detail about the issues you had with the DW pumps? Was it an isolated issue or common?
I had a couple fail on e85 builds, and the warranty process is farked. Now I just stick to e85 Walbro's as they are cheap ($185) and they work flawlessly. (Unless you try and run water through them :P)
The e85 Walbro uses turbine tech, not gear pump. They are silent.
I like that Radium review, Thanks Tim.
I can't see a Walbro 255 being noisier than a Bosch pump though, perhaps the 044's get noisier over time? It wouldn't help that most are externally mounted I guess.
The early E85 walbros had an issues if not submerged fully, the later not so much, I have the newer E85 walbro in my 34 as a lift pump and have run it way down past the pump hieght with no issues :)
What sort of issues do they have? I've got one mounted in the standard position in tank (r34 gtr). Should I be trying to mount it further down the mount like in a 34 gtt?
Do you have problems with fuel surge under 1/4 tank ?
If not you must have a " newer " one, if so you will need to lower it or swap it out
Personally, I wouldn't waste my time with a walbro externally. There are better options.
Aftermarket industries makes beautiful surge tanks, and they also sell the Holley Dominator 1400 and 1800 external billet pumps.
Worth every cent.
http://www.aftermarketindustries.com.au/fuel-pumps--accessories-c3/holley-dominator-1400-p180/
http://www.aftermarketindustries.com.au/fuel-pumps--accessories-c3/holley-dominator-1800-p92/
Okay, assuming I don't want to make 1000hp and have a mild setup and already have a surge tank and am just looking for an external pump. What else is out there besides Bosch (have had great experiences with Walbro so would like to stick with them of possible)
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
