Hello
As I build up my r32 gts-t, I am learning things.
I will now see what it is like to drive with a boost controller on the car. Later a turbo upgrade.
Wondering, if later I want more power, is it better to put a rb 25 engine in the car and upgrade? Put a rb26 in the car and upgrade? Or just save money for a while and get a r32 gtr? Will the features on the GTR be worth it or will putting a bigger engine in be better and more cost effective and sensible?
I have researched what the engines can do, just wondering what would be the most sensible route.
https://www.sau.com.au/forums/topic/446825-changing-engines-or-changing-cars/
The real smart option is sell the un-built-up yet car and buy someone else's finished project car then change the styling/bits to suit what your end goal is.
This saves you monstrous amounts of time and money in the long run.
Are you in Japan or Aus? You can buy already modified GTR quite cheap in Japan. But for example in NZ you can get a well modified R32 GTR for $30 - $35K or buy a stock one for $20k and then have to spend $30k to get the same thing.
A few points.
No-one in their right mind would put an RB26 into an R32 when a Neo RB25 is a better motor.
No-one in their right mind would put an RB30 block based engine into an R32 unless they like bonnet clearance problems and doing stupid things like lowering the subframe to make it fit.
R32 GTR will send you mad and broke unless you spend a lot of coin to buy a really good one. Anything that is old and much used will always be breaking something annoying and expensive to replace. Better off buying an R34 GTR.
A few points.
A few points.
I live in Japan
Early model r32 gtr getting expensive because can be imported back to the states legally now. 91, 92's and 93's are still ok.
Why is the RB25 neo a better option? I reseached putting Rb25's in(non neo) and it seems to be difficult because of the wiring and so on.
R34 GTR still close to 30000 dollars here.
I like the idea of the ITB on the 26.
Edited by yoshiii335
Neo 25 is basically the same capacity as RB26, has variable cam timing. Has the same type of solid lifters as RB26, same oil pump, same conrods. Made same power (officially, actually less in reality) as RB26 when new. But the actual power potential of the base engine is about the same as RB26 - just with variable cam timing on top to make it nicer to drive on the street.
it is a no-brainer.
And if the wiring work required to fit a 25 of any sort is too much trouble, then the work required to fit an RB26 will be too much also.
ITBs are nice, but in real terms you woul dnever know the difference whether they were there or not.
R34 @ $30000 sounds like the way I would spend my money.
  • Like 1
it is a no-brainer.
Ok I will look into it more,
R34 is nice but there are other more important things to spend 30000 dollars on than a r34 gtr at this point.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
