I for one would liked to have seen you there Brian
There was another red r35 and the run I saw was a 13.6
Was awesome to watch :D
Especially the side x side down the strip
Big laugh watching the Motive DVD turbo diesel have a go - bahaha
but their black 32 hauled arse hard
Would have gone down if the team needed me to, but i think the SAU team selected would beat my R35 im only good for low 11's. maybe a high 10 with E85 as its set up for WTA. Not sure what the other R35 from the HSV club is doing only 13.6? Should be in the 11's easily
The red r35 driving for the commodore club did an 11.2. The driver was 75 yrs old lol
We won the day and the series. Down by a bit coming into this round, and ended up 180pts clear!
Luckily for us the quickest evo (10.8@149 I think) wasn't on the evo team. Evo team was mostly running 12s.
I find it exciting when horsepower wins from behind on the home straight!
Congratulations all from #1 to #3 :)
Big thanks to NULON a great Aussie Company for organising this 3 event series!
Well done to everyone on the team and thanks to everyone that came out to support!
Unfortunately on my first run (where I was deliberately taking it easy) turned out tone my only run for the day with the alternator coming loose and pushing off all the cars belts, also catching them in the fan and pushing it into the radiator. Belts were easy to solve but fat chance finding a radiator in Cootamundra!
Still, was happy that even on a test run my car was effortlessly putting out 141mph!
maybe it's time my bitch hauled some arse in some SAU events and payed her way in life (bloody prima donna)
PS. good to meet see you again Black Templar :thumbsup:
Edited by Sinista32
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
