1. cant upload pics (even when cut down to less than 300kb) Msg = The server returned an error
2. getting randomly logged off, and
3. cloud errors on recent threads :/ Msg = standard cloud error msg 505
Using IE10
Edited by Sinista32
I'm getting errors and randomly logged off as well. but my error code says error 502 bad gateway
lol - I need glasses as it is a 502
Thanks Christian ( I hope you had a good day at the 25th :thumbsup: )
  • Like 1
Thanks man, were you there?
Also, are you getting these after you submit the post or when uploading the image?
#@ARTZ are you using sau domain or skylinesaustralia when you get logged out?
Sorry about this guys, I'm trying to sort it. :(
I had to start using SAU domain because skylinesaustralia makes me keep logging in.
Yeah try that, there is supposed to be a redirect from skylinesaustralia to sau but its broken... of course. :(
Teething problems!
Still getting those 502's :(
I also work in IT so I feel your pain! :)
Can you go here; http://www.sau.com.au/cdn-cgi/trace and paste your results.
Also, is it a graphical 502 or just a text error?
Results:
fl=26f8h=www.sau.com.auip=202.46.141.48ts=1408187045.663visit_scheme=httpuag=Mozilla/5.0 (Macintosh; Intel Mac OS X 10.8; rv:31.0) Gecko/20100101 Firefox/31.0colo=SYDspdy=off0
And nope, looks exactly like the pic I posted above and above it says:
"Website is offline
No cached version of this page is available."
Has a button to retry for a live version.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
