Image uploads working.
The file system changes may take a little while to be reflected on all the servers, so if it doesn't work for you, refresh and try again.
I had to start using SAU domain because skylinesaustralia makes me keep logging in.
this..but when I log in via skylinesaustralia it says I have no permission and redirects me to SAU domain
It might now be fixed guys, let me know ?
not sure about gateways but still redirecting me to domain
    • I hope so.  It seems pretty nice. OEM feel the lot.
    • I wouldn't be surprised if this helps. And I wouldn't be surprised if it keeps changing for a bit after the new slave&hose go on, because I find that my clutch always does this sort of shenanigans after any serious dismantlery. And then it settles down after a few corrective tweaks such as you've already done.
    • Ist post I joined after seeing this thread  I have just installed on a r33gtst at first I liked it but I am finding the peddle free play changes …. To a point I have had a zero free play condition and the thrust bearing stayed engaged. I had to back off the adjustment on peddle.   I am about to change slave and fit a braided line to see if I can get a better result
    • I sent off a message to a guy, waiting for his response if he can do it or knows someone.
    • Just remake the bracket. It's just bent steel with a nut welded to it. It is thinner material than you might remake it in. You just have to get the thickness right in places where it absolutely must be (and there might not actually be any such places. The same motor trimmer who you get to work on the outside of the seat would no doubt have done exactly this type of repair in the past.
