Getting this error msg now when selecting more reply options to upload pics
"Sorry, you don't have permission for that!"
Was successful once and then the above msg on next few attempts
I'm not being logged in automatically. When I do log in, I get:
I'm still sorting out the redirects, the problem is probably because you're going to skylinesaustralia.com and not sau.com.au.
Sorry, must have missed the news about the change of domain name.
Made the change in my bookmarks, and it seems to work as before.
Tks
Still getting a lot of 502 and some 504 errors accessing SAU
Really??? When was the last one?
What URL were you visiting?
http://www.sau.com.au/forums/forum/51-nsw-members-area/
Threads within here and even http://www.sau.com.au
The last one I had was just minutes before I posted that. I couldn't get onto SAU for around half an hour this morning.
Can you please take screen shots next time and upload them to the Downtime Registry thread? I haven't had any problems for days and I cant find anything in the logs. Might be a caching problem
Sure thing! I think the 502s were the same as the one i posted earlier but I'll start capturing it a lot better for you. Will note down times etc too.
I'm not working at the moment, life is boring when SAU goes down! LOL.
  • 3 weeks later...
Prank - may be a co-incidence but on the last two times i've uploaded a pic, i get the cloudflare 502 immediately after on any sau.com.au URLs. It occured just now with a ~250k file. I can supply ntp squid logs if that helps.
Yeah I've kinda had it and will be creating a new image to base new instances on this weekend. Its driving me nuts!
Does the image upload work? Even if it throws an error?
The image upload works but the next page after that dies. The third image i uploaded (second for today) seemed to be ok though...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
