FWIW The pcv is only evacuating blow by that is on idle/cruise i.e vacuum....when putting more pressure in the crankcase by way of rpm and boost the cam breathers are doing the most ventilation.....just plug up the pcv valve and use the cam cover breathers to a catch can if you have no legal issues with emissions control.
  • Like 1
Ohhhhhhh!! I understand!
So all this time I was concerned that the suction would cause the PCV to shut but actually the ventilation whilst on boost was never through the PCV valve at all!!!!
So if I'm blowing oil out of the dip stick, there's a problem with the Venturi not creating enough suction on the exhaust cam cover breather given that there is exhaust back pressure. Right so now to fix!
This is a really good community, I'm grateful for your help and understanding in me being pretty oblivious to this part of the engine management.
Edited by edizio
  • Like 1
yes but what you'll find is only having 1 venturi or flute to try and create enough vacuum to remove the crank case pressure is not enough and why the pressure is building in the crankcase and popping out the dipstick. There are 2 breathers off the top of the cam covers....you need at least this piping volume to evacuate the crankcase pressure, on factory setup they join them and plum them into the intake in front of the turbo which creates the vacuum necessary and also meets the emission controls for being legal.
Ok, so why vent to atmosphere when I could plumb up the dip stick with a one way valve so that it could breath in but not out and then let the vapour exit all through the cam cover breathers?
Or is this going to become a problem, once again, due to back pressure?
I typically just pull the catch tank tube off and stick the dip stick in... Which is a pain because I check the oil before and after I go for a drive!
The car only comes out on nice days.. I use my motorbike or other car otherwise. She's too nice! And too quick lol
Because you really don't know what your exhaust pressure is. If you are venting to atmosphere you do know what the pressure is. Also by an additional venting point you are equalizing the engine pressure and not relying on one point of relief.
At the end of the day whatever you have now isn't working very well. So maybe just try what has suggested and see how it goes. Sometimes you just have to do what's been proven to work and not get into the paralysis by analysis trap which sometimes we are all guilty of.
Hey guys, so an update!
I spoke to the car builder and he said that I could go atmos but the Venturi always worked for him and he never saw oil coming out as the suction was always sufficient so perhaps I should investigate further due to this being odd behaviour
So upon investigation, I found that I had a leak in the half moon seal on the exhaust side where oil seems to be leaking out so I've ordered a new half moon, cam cover gasket and bolt seals. I'm pretty certain that a leak in the cam cover would result in some funny behaviour so I am going to investigate a bit further.
His advice is that if I want to go to atmosphere, like you guys recommend, I'll need 2x 12AN hoses to be sufficient enough to vent.
I'll wait until the parts come and fix the car myself and then see what the behaviour is like.
PS, red metallic rb26 rocker cover with old and ugly breather hoses. What colour samco hoses would look nice! I'm totally crap when it comes to things like this, which is evident because I'm thinking purple!! Lol
That looks great, I've actually got stainless braid for my fuel lines and for the exhaust Venturi but standard rubber on the breathers at the moment. Quite tempting! I'll keep posted on what I decide and take some pictures.
It'll be within the next week or two that I fix the leak so I'll probably order something in once I decide what I am going to do :-)
I personally like stainless braid, but go with whatever makes you happy as you'll be the only one that sees it.
This is what my engine looks like...
Very nice. I like braided lines but I use rubber hose cause I'm poor. BTW what kind of plenum is that?
Im thinking the reason that you perhaps have the leak out of the half moon seal is the setup you have pressurized the cam covers with your current setup
Just vent atmo (including blocking the PCV valve) in a subtle way and be done with it. E.g. just like Ryno's setup above. The hose coming out of the can can go down to breathe out below the car (but made to look like it is going somewhere legit in case the 5-0 has a brief look under the bonnet...)
Edited by jjman
Pressurising the cam covers doesn't sound good. That would imply that I'm getting positive pressure from the exhaust wouldn't it? Which is weird because I tested the one way valve to make sure no exhaust enters the system..
Chances are I'm going to go with the atmo setup with the 2 12AN lines like you guys recommend, it doesn't look hard to set up either. It's a shame though, as you guys write, in theory the Venturi system seems like it should work.
No, the engine itself pressurises the cam covers (which are in the same volume as the sump!) by blow-by past the rings. That's why you have to have a breather system at all. The PCV system cannot suck the crankcase gases into the intake manifold under thos circumstances because there is boost in there.
And to make matters worse, the one way valve in your exhaust venturi is set up to prevent any flow from ever going out to the exhaust, so even if it could suck the crankcase gases out (assuming the venturi works) then it won't.
That's why none of this silly circus works. Piss it all off, start again.
  • Like 1
If you look closely you will see the engine is a RB25DET, the plenum top was made by MX Performance in Sydney... I'm not sure if he's still in business (as I can't find his website anymore) however I'm really happy with it - similar quality to Plazmaman and a little better price wise. I also run a MX Performance exhaust manifold, it has 1" runners and spools the turbo much earlier than the stock manifold.
Yes, will probably replace the system :-)
Although! The one way valve should only be letting gases go back down into the exhaust and not up into it. Didn't quite understand what you said there
I quote from your original post.....
"any kind of hard suction on the PCV valve from the exhaust side causes it to shut"
I read that to mean that the one way valve will not permit flow in the direction engine -> exhaust and will only permist flow in the direction exhaust->engine, which is of course the wrong way around, which has already been said by somebody earlier on in this thread.
So when you are on boost you have nowhere for crankcase gases to go at all. The PCV connection at the intake manifold will only suck on the crankcase when the engine has vacuum, and the venturi will NEVER suck on the engine.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
