Your explanation of the PCV is making sense to me; however in this scenario, wouldn't the PCV still be closed even though the crankcase is under positive pressure: -
It depends on how much negative pressure the Venturi system is creating and how much positive pressure is in the intake, as soon as there is boost in the intake the PCV closes and the gases are meant to go to the I take of the turbo
[\quote] I'm driving hard on boost - Positive pressure in crank case causing the PCV, negative pressure from the venturi in the pipe leading to the valve. In this scenario, I would expect the valve to be shut but shouldn't it be open to vent the crank case so that the blow by isn't just venting out of the catch tank - it obviously has no where else to go does it?
That's right, the positive crankcase pressure should be getting sucked out by the Venturi since the is boost pressure in the I take manifold it can not go in there as the boost pressure will cause the PVC to close
[\quote]So, I then take my foot off the gas and theoretically I should be in a vacuum/negative but the crankcase won't have vented because it has no where to go so. I then have very little suction (well a little bit), from the venturi port and still positive pressure which means the port is still closed...
This is when the PVC will open and draws gases away from the cam covers pulling gas out of the crank case, the PVC is controlled by the intake manifold unless the Venturi system is creating a higher vacuum level
[\quote]
This is what I don't understand
This is the PCV valve that the venturi port connects to:
Now, I see that in some race car setups, they actually have a vacuum pump; even in this scenario, isn't the PCV still always just closed?
The Venturi connects to the exhaust side cam cover, the PCV connects to the intake side cam cover and the two covers are connected to each other but both have the volume of cam covers and head and well crank case to draw from effectively separating them from each other
The crank case should never be in negative pressure with out external help as even at idle there is blowby just not much
The vacuum pumps that race cars have is because they are using stupidly long duration cams and have lost the intake vacuum in doing so so they have to create it somehow, which should not be connected through the PCV as it would just cause it to close
Okay right, so I have custom intake and exhaust cams on this car! (TODA 264 9.3mm).
Currently with the operation of the PCV valve though, if the positive pressure inside the crankcase is higher, the valve remains shut? because that's currently what happens if I simulate the effect by blowing on the side with the screw
The PCV screws in to the balance tube on the intake manifold so the threaded end is seeing what ever the intake manifold is doing
So vacuum created by shutting the throttle bodies opens the valve and when the throttle bodies are open and boost is going into the intake manifold it closes the valve :thumbsup:
264s are not stupidly long duration, 280+ is getting stupidly long :(
Who does your tuning and what ECU have you got ?
Hey,
So, this is where the PCV is connected to; straight off the end of the black pipe that comes from the intake cam breather. I thought that's the valve cover not the intake manifold.
I have an Apexi Power FC ECU; I do a lot of the tuning myself and with the original owner but I'm ok with the tuning aspect; I built my own det cans and have the AFRs at 11.5 on boost with 12 coming on to boost. I run idle at around 13.9 as the cams don't take idling at 14.7. The ignition timing is a bit more convoluted to explain but that should be good too. The CAS is set by the original owner and I haven't touched that and the boost controller is a greddy protecB that I manage the boost with.
We use venturies on our mining equipment to vac out the dust collectors on the air filter box's, but the actual venturi pipe is located just inside the tip of the exhaust, so as the gas expands out it creates a negative at the end of the vac pipe,
It took quite a bit of trial and error to find the perfect distance from the tip, but it wont inside the exhaust near the turbo with that much pipe left!
  • Like 1
Lol! yeah quite correct... it did work kinda but if your oil air seperator isn't up to the task you just draw through oil vapour and make a nice smokey exhaust. i still have one connected....but my issue was not ventilating enough i.e venting through a size smaller than the two 5/8 vents off the cam covers effectively pressurizing my catch can.
Xgtrx, no, positive pressure from the exhaust never reaches the PCV because of the one way valve. My original post shows the valve that stops any exhaust gases travelling back up.
If exhaust gases were getting up, they would actually open the PCV valve which is what I don't really understand and I the opposite case of what I've been asking about
Yeah but if both valves are closed when the car is on boost, where is the positive crankcase pressure going, the only way out is through the dipstick, yes? It can't be scavenged through the exhaust because the exhaust gasses would causing positive pressure compared to the crankcase. Or have I got this totally wrong?
That is correct except for the reasoning behind why the gases aren't being sucked out. They aren't being sucked out because any suction closes the PCV valve, which surely can't be right?? and I believe that's why oil is going out the dipstickbut I can't understand why someone clever enough to build an engine and set up all the timings etc would fit a Venturi to a valve that never releases any positive pressure from the crankcase. It seems to me like if a Venturi is being used, then a PCV valve is not the correct valve to use.
I am not advocating for or against the use of Venturi to create negative pressure, nor am I saying I will keep this solution, but if this setup, in theory, were supposed to work, how would having a PCV valve connected do anything if it only opens on positive pressure from the exhaust side, for which there never will be any because of the one way valve not allowing any exhaust gases through. The tube that connects to the PCV in this setup is always under vacuum. The Venturi is creating good suction at idle and even more as the rpm increases which implies to me that all PCV valve will never be open.
Your thinking to big picture and in this case that's not how to do it
What you have is two differential valves, one is controlled by the intake manifold and the other is controlled by the exhaust pipe and while in theory this should work the practical side of mean both valves shut at the same time
The intake one closes as soon as the throttle opens, when the throttle is open the exhaust gas increases to the point there is backpressure which closes the exhaust side one
now this is where you need to read carefully, while there is more pressure on the outside of the valves then the inside they remain closed so the crankcase is building pressure from blowby which is lower then the intake pressure and exhaust back pressure it has nowhere to go except out the dip stick tube
What you need to find out is what the Venturi is doing at full noise when the exhaust back pressure is at its highest and the motor has full boost level
  • Like 1
Xklaba, starting to understand I think.. Although I can't imagine that much back pressure. It is 4" all the way through to a tiny back box and doesn't have any cats.
Maybe I'm still a little confused but am I wrong in thinking that the gases should be escaping through the PCV valve?
No exhaust is going to have zero back pressure no matter how fee flowing it is. The exhaust is being pushed into the exhaust pipe.
I have to disagree with that, an old mate of mine had an exhaust that was 3" dia and 4" in lenght with seperate screamer pipe on his turbo R1 :D
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
