So that is the filter relocator part of the setup yeah ? Not the part that bolts to the block ?
Why would that bit get removed ?
Can you remove the one from the block and see if it will screw in, at least that will tell you if its 3/4 unf or not
Its M18 but not sure on the thread pitch sorry
Go to a wrecker and find an old VL or r31 with an rb30 in it and Rob the fitting out of it. That's what I did
Wow, so it is the same as the factory RB30 fitting that holds the oil filter, interesting :)
I'm pretty sure it was M18 because I had to run a dye over mine. there is a definate step down in the VL filter stud from the filter end to the end that screws into the block and seen as 3/4 is pretty much 19mm I'm fairly certain its 18mm.
Just go and grab one of them, must be close to a wrecker that has some old VL's? There are heaps of them where I am, and I'm not in a huge city.
OR am I misunderstanding how the GREX plate works? mine had a female 3/4 thread to go onto the filter stud to hold the sandwich plate on then had the male 3/4 end sticking out the other side for the filter. The fitting circled looks a bit different so maybe I'm way off in my way of thinking? Not sure
Anyway, I couldnt find the part number for the stud when I was sourcing mine, but if you could find this then a quick trip to Holden/Nissan would net you a brand new one. Maybe go ask Holden and they can look it up. they generally require less information on the vehicle than NIssan. But again that all depends on if I'm thinking on the right lines or not lol
The thread in the greddy plate is bigger than 3/4x16unf...
The grex plate is the relocator plate, it sits at the top of your engine. It was a male screw in adapter stud (unsure what size) the other end of the stud houses the oil filter (3/4x16unf).
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
