It is a GTR yeah ?
You are turning in a little early and getting on the power a little late, get to know your ATTESA and trust the 4WD to pull you clear of the corner
It also looks/sounds like your single pegging, get the LSD looked at
And for the love of god DO NOT CROSS your arms :no:
https://www.sau.com.au/forums/topic/446971-track-pointers/#findComment-7367983
It is a GTR yeah ?
Its a GTS4 with a 26 in it so pretty much - I'm the guy that bought your brembos - stockies caught fire the session after that video
good call on the cornering, definitely got to build confidence now that i have some real brakes
Also with regard to crossing arms - i hear differing feedback on this - why not cross?
Edited by LuckyTune
https://www.sau.com.au/forums/topic/446971-track-pointers/#findComment-7367989
I'm also having trouble on the track and might upload one of my vids tonight. I find it really hard to keep corner speed up and the car seems laggy as I exit the turn.
Most of the time I have cars with 100+ less kw pull away from me out of a tight corner. If I try to exit any harder the car just under steers.
https://www.sau.com.au/forums/topic/446971-track-pointers/#findComment-7367991
Oh yeah, hello
How did you go fitting them ?
I have since removed the Nismo Brembos and fitted some AP 6 pistons :)
If the car gets way out of shape mid corner your arms are tangled, read the corner and set your hands before entry and prepare for/expect it to go wrong and hope it doesn't
I have a bad habit of driving one handed lol, I have a video of me punting me 34 around Wakefield power sliding it out of the last corner and I look like I'm a Sunday drive hmmm
What LSD does it have ?
I have Whiteline sway bars in my 32 and cusco in the 34, go the adjustable white lines :thumbsup:
https://www.sau.com.au/forums/topic/446971-track-pointers/#findComment-7368029
clamped the hubs up lice crazy, linished a rod down to the right size to centre it all before drilling and still managed to get off centre holes haha.
All bolted up sweet though
10303468_10151983409096710_3973187679836
yet to see how it holds up on the track but I'm hoping i will at least get a full day!
haha i wish i had the coin to go all out on mine - one day.
stock diff as far as i know, was going to shim it because i need to replace my attesa pump so its got to come out anyway
Just ordered a front and rear whiteline kit - should make a difference
Edited by LuckyTune
https://www.sau.com.au/forums/topic/446971-track-pointers/#findComment-7368040
I rather strongly disagree with that statement :) Taking your hands off the wheel means that if it gets away from you mid corner and the wheel spins in your hands you have less of a hope of knowing where straight ahead is. Of course on the tight slow stuff there is always a compromise....but persoally I ama BIG believer in never taking your hands off the 3-9 positions on the wheel
https://www.sau.com.au/forums/topic/446971-track-pointers/#findComment-7368121
i'll definitely take the hands advice onboard.
that was with r888's - best lap i got was a 44.something - but as mentioned before it was with almost no brakes (they let go and caught fire leaving zero pedal at the end of the straight, tested the run off)
https://www.sau.com.au/forums/topic/446971-track-pointers/#findComment-7368311
Lol, Murphy's law :)
Those brakes as a set held up a few full days hauling up my 300kw R34 which weighs a hefty 1661kg + my fat arse, your nice lite 32 will be like retirement for them lol
Michael, got a dyno sheet, what's your mod list ?
-7's on E85, 325rwkw @20psi. I'm guessing there is something wrong though as I only saw 15psi on the weekend but the car still seems to go hard. It's just lagy is all.
http://i.imgur.com/M2jmBoJ.jpg
https://www.sau.com.au/forums/topic/446971-track-pointers/#findComment-7368394
Crossing your arms is not only perfectly fine, it's better than repositioning your hands on the wheel. Keeping your hands in position means you know exactly where the wheel is, and you're in a better position to make any corrections needed. There's no situation in that video that requires your hands to be repositioned before the corner. Only when you need about a full turn of lock would you reposition your grip before a corner. Pretty rare on a race track, even a tight low speed course like that. Mt Cotton Hillclimb's hairpin is about the only corner I ever need to do that for, and when I do it I end up with my right hand crossed back over to about 9 o'clock so you're ready to wind lock off if/when needed.
All the pros cross their arms, and keep at least one hand in position unless absolutely required.
https://www.sau.com.au/forums/topic/446971-track-pointers/#findComment-7368466
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
