My comment would be this. After a certain point you don't get more grip from the front tyres when you turn the wheel more. So once the tyre has reached its peak of lateral grip turning the wheel more will only increase the amount of understeer you get and not make the car go around the corner any quicker.
See here, just over half way down.
http://farnorthracing.com/autocross_secrets22.html
Trick is finding how much lock that is at and resisting the urge to turn the wheel more. Much like resisting the urge to turn in too early. Comes with practice.
One point: position your car for the corner coming up, once your car is in the corner, think about the next one. Sort of hard to explain, but works well on the track (especially on S bends).
The best way to explain this is "keep your eyes up". People sometimes tend to watch their front end going around a bend, keep your focal point up and pick your markers to drive towards. I am pretty new to track days myself but this is the best advice I have been given as a NOOB and once I started to do it, I started to catch cars that drove away from me previously.
^ well said, I heard that advice off B. J. after an Oran Park track day (he had a pro sit with him). Made a very noticeable improvement in my driving.
Was going to expand on my previous comment about hand positioning. For me, it's more with having confidence in the car/grip. Since I've done only a few track days, and having crappy front tyres, at Marulan I did't use the 9-3 position as much, since wanted to have a bigger range of motion mid corner (car was a bit skittish). At Eastern Creek South, since the corners are a bit more smooth and 'round' (plus slightly better tyres), tended to hold the wheel at 9-3 a lot more.
Understeer is understeer. I tried the 'slow in, fast out' approach so the car would get out of corners abit straighter, but crap tyres were crap. Also OP, did you find the R888 fall off after a few laps? I noticed this in fatz's BNR33 at EC south (after 3 -4 laps they started over heating I guess), and he complained about it a few times too.
Definitely noticed some fade, and the front left melts like crazy at Marulan - but my brakes were cooking after a couple of laps so i was slowing down somewhat anyway and probably didn't push them too hard.
That said, i have run the same set for 5 track days (although probably only about 2 full days of driving in total) and they still have some meat left on them
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
