xtra.5 Posted August 18, 2014 Share Posted August 18, 2014 Parting R32 out. Got a few things to put up now. Lots more to follow when i get time. All items can be picked up in either Melbourne Sth Eastern suburbs (Glen Iris area) or Traralgon. Call or message for more info/photos etc. Mike 0412 678 973 RB20DET Manual Conversion kit with C's short shifter. Comes with everything EXCEPT flywheel - clutch is pretty much stuffed as well. Gearbox is in great condition. No notches, clunks etc. Selects all gears perfectly. Package includes: - Gearbox and crossmember. All bolts included. - Short shifter. Been told by previous owner it is genuine C's. I got no way of proving if its genuine or non genuine. Worked great though. If someone knows of a way to tell if its genuine or not let me know. Shifter has also been cut shorter and re-welded back on. - Tailshaft. Can supply either ABS or non ABS shaft depending on what is required. - Clutch and pressure plate. Both pretty much stuffed. - Pedal box, master cylinder and slave cylinder inc all pipe work and bolts. - Rubber boot, leather shifter surround and plastic surround. Leather surround is a bit worn - as consistent with a 20-25 year old car. Plastic surround has a crack in it at the bottom but is hardly noticeable and can easily be glued back together. Chasing $850 Top Mix Racing Seat One piece, fixed back, fiberglass race seat. Set up for a fixed position in R32. Im a big bloke so set up quite a fair way back from the steering wheel. Mounts were made years ago and are a bit on the dodgy side. If purchasing i would recommend making new mounts up. $100 R32 GTS-T standard drivers seat. No stains, rips or tears. Foam on right hand side of backrest is a bit dodgy as shown in 2nd pic. Can feel the metal bar underneath. $50 R32 GTS-T standard passenger seat. 100% Perfect condition. $50 Link to comment https://www.sau.com.au/forums/topic/446990-vic-r32-rb20-det-gearboxmanual-conversion-with-cs-short-shifter-racing-seat-standard-seats/ Share on other sites More sharing options...
skylinekid_9 Posted August 20, 2014 Share Posted August 20, 2014 i see a few pats id def need Link to comment https://www.sau.com.au/forums/topic/446990-vic-r32-rb20-det-gearboxmanual-conversion-with-cs-short-shifter-racing-seat-standard-seats/#findComment-7370049 Share on other sites More sharing options...
xtra.5 Posted August 25, 2014 Author Share Posted August 25, 2014 Still for sale. Make an offer Link to comment https://www.sau.com.au/forums/topic/446990-vic-r32-rb20-det-gearboxmanual-conversion-with-cs-short-shifter-racing-seat-standard-seats/#findComment-7373283 Share on other sites More sharing options...
xtra.5 Posted September 4, 2014 Author Share Posted September 4, 2014 Prices dropped. Conversion kit - $750 Racing seat - $80 Standard seats - $35 each Link to comment https://www.sau.com.au/forums/topic/446990-vic-r32-rb20-det-gearboxmanual-conversion-with-cs-short-shifter-racing-seat-standard-seats/#findComment-7382355 Share on other sites More sharing options...
