Hey Guys,
I'd like to know if anybody know how much are these GT-R Body shells (R32, R33 and R34) are? I am considering a project to enterain meself for a year or two.
I've searched all over the net for prices but i can't get the price for body shells, anywhere and would like to know how much is it and where is it all this...
Your opnions would be good and also some tips...
Cheers
McJeff
https://www.sau.com.au/forums/topic/44701-for-gt-r-body-shells-anyone/
well you can get an r32 GTR landed from about 10k including all running gear (not that it would all be running :D ) But if you need to register the car you would need to either buy a 15 year old car or buy a full working undamaged stock car to import under sevs rules.
If you were going to get a cheap R32 GTR it would have to be a project car because they all drain big money when things break
Ide get one and also buy a cheap car i can use for work etc
First get the engine out and worked on by a good rebuilder/workshop, while thats happening do alot of the body/suspension/interior etc work yourself as its not quite as hard and u can save alot of $
depening on how much u have upfront to do it up, shouldnt take more than 6months tops,
worth it if you got the time & money, you basically get a brand new gtr for less than the price of a used one
Personally I would go with something that is mechanically a bit simpler than a GT-R -- between 4WD, twin turbo, HICAS, ABS, etc, etc there are lots of bits that can go wrong and will cost you a fortune to buy bit-by-bit. I would look either at an older Skyline (you could always copy Duncan, the luck bastard) or perhaps something else with a strong community. Personally I have always wanted to do an AE86 to truely worship the rice boy within me -- "LW say, follow the path of Takumi-san: AE86 for you" :P
(Although I am being a little silly, I am quite serious though..)
Lucien.
Personally I would go with something that is mechanically a bit simpler than a GT-R -- between 4WD, twin turbo, HICAS, ABS, etc, etc there are lots of bits that can go wrong and will cost you a fortune to buy bit-by-bit. I would look either at an older Skyline (you could always copy Duncan, the luck bastard) or perhaps something else with a strong community. Personally I have always wanted to do an AE86 to truely worship the rice boy within me -- "LW say, follow the path of Takumi-san: AE86 for you" :D
Lucien.
GO THE TOFU SHOP! :headspin:
I really need to go sort my ****ed friend out, picked up a AE86 as a trade in (he works at the dealer) for $1500......PRICK
For an Australia delivery AE86 with 4AC, that cheap but not all that fantastic (depending on condition, particularly rust).
LW.
Hey,
How about combined with all three?
And how much you guess it'll be building all up? 20K? 30K?
Cheers
McJeff
McJeff
I did this. Bought a clean (not F*cked) GTR, rented a shed, pulled it apart - everything, dipped shell, re built - everything, re- assembled to concoarse standard, modified many things along the way for performance/reliability etc...
Total build time - 4 years. (using mainly weekends and nights) (I am an experienced marine engineer by trade so I knew what I was doing)
build cost - $80G plus.
Was it worth the exercise? - doubtful
Would I do it again? - Absolutely!
Did I lose money when I sold it recently - yes, obscene amounts.
Overall, not a task I'd recommend for a 17 year old for a first project. Get a Datsun 1600 or something!
LW.
Put it this way, I'd of ripped the interior out of it 'drift spec' :thumbsup: But seriously, obviously didn't look the dogs balls, but for $1500, pretty nice :) Cheap to run, 4cyl rwd transport, can't go wrong :(
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
