Up for sale
Volk Racing Emu
multi stud 4/5 x 114.3
Set of 17"
White in colour
235's all round,
235/45/17 achilles fronts are 1-2mm from indicators
235/45/17 nexon n6000 rears are 2weeks old
f: 17x8 +35
r: 17x9 +40
couple grazes here n there nothing too obvious tho. come up nicely with a good clean.
might be able to throw in a couple extra tyres.
Price: $900
sms me on 0409 022 02 three
1512660_10152641752586972_67621609972941
https://www.sau.com.au/forums/topic/447013-vic-volk-racing-emu-17-white-cheap/
  • 3 weeks later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
