Hello
I learned about 550cc injectors made by a comapny called Deatschwerks. I tried finding info about them on the web and cant find many reviews. I have read that people use them but no one has really put up a review about them.
Does anyone know if they are good injectors for the rb20 or should I stick with Nismo, Sard, or Tomei?
Edited by yoshiii335
https://www.sau.com.au/forums/topic/447036-deatschwerks-injectors-any-good/
I got the 444 from them. The flowchart that came with mine said they're matched around 458cc.
Really noisy, the idle is a little more erratic than with the standard ones but nothing to worry about, AFR are stable on idle, cold start or hot start are as good as standard.
No problem so far with 10 000 km on them on P98.
The only downside is the noise, if I had a quieter exhaust the only thing I could hear would be them.
Double check the latency, I chose the 444cc because of it, the 555cc latency is almost two times longer from memory, and I didn't really need much more on P98 anyway.
On E85 I would buy the 650cc directly.
They come with adapter plug so they're really drop in.
Just excite them with a battery before installing them. I had to excite one directly from the battery to get it to open. Then it worked like a charm.
I purchased mine directly from their site.
Really? Really?
Their sidefeeds are as good as water pistols, similar to Five-O Motorsport Garden hoses.
Since its a RB20 I would just go EV14 or IDs if you have the cash to burn.
Im using their 700cc. Noise is about the same as stock GTR. They are a touch fluffy at idle, but a
power fc idle reset got rid of most of it. Pretty common on any aftermarket injector larger then stock.
I am of the opinion that they over rate their injectors
I have their pump as well and that has been tested and around 10% over rated- although they might test with no lines, I tested in the car. Pretty stupid to rate a pump without lines
Maybe alter the search parameters to "hydrolock, Deutschwerks" and you should get some hits.
Same goes with Five-O Motorsport... I made the mistake of buying a set, recently just spent a kidney new injectors.
However being a RB20DET, and with your power goal in mind.. Stock 444cc GT-R injectors would be tits.. drop in, wire up resistor pack, rescale and off you go
I have a set of Deatschwerks 550s in my car now - have had them for about 5 years and they seem ok. However I believe they are just "remanufactured" Nismos or something and when I upgrade I will be getting IDs or Bosch or whatever they are.
DW, Five-O, ANSU, all they do is get a JECS injector and grind off the 4x hole tip which helps with the spray pattern. They then carefully enlarge the remaining single hole to increase overall flow.
I've had a look at both side feeds, and I actually own a set of Five-O and how they're produced are identical... If you look carefully you can see grind marks.... it's sad.
I have them and a pump in my old rb20 in the 32.
They seem fine, im running an rb25 turbo at 14psi and Nistune as well.
182.8 kw safe (a little rich) tune.
The best thing about them is the ease of install, they just go in like Nissan parts, no fking around.
You wont need to worry about correct resistance like if you get gtr injectors.
You get a test flow chart and spec sheet for your tuner.
So... cheap, maybe crap quality like others have said, but ok for small goals, and very easy to install.
It all comes down to the old questions of your goals and budget.
Soo much miss information here.
DW are not jecs not even remotley close. They are bosch.
They do not have re-drilled single holes and do provide a accurate spray pattern.
However this may be true with other brands mentioned.
My Dw have been perfect so far.
I had no difficulty installing.
Tuner had no probs what so ever, neither has running idle through to Wot.
Jecs left , Dw right.... ahh bit more than a hory regrind n drill hah
please read what I wrote properly dude.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
