^ haha all good :)
The thread did digress a little - DW Top Feed Injectors I haven't had experience with, however it does look like re-manufactured Bosch injectors... Similar to other top feeds.
I have DW 1200cc top feed injectors in my GTR and used to have in my Gts-t... Both idle like stock and work very well for economy and power! I had some DW 770cc top feeds in my old RB20 as well, also perfect.
I know a few people who have also jumped from Bosch 2000cc injectors after having issues with idle and them blocking over to DW 1200s and now having no issues at all
Yeah, but to be fair, DW 1200cc and the Bosch 2000cc are basically the same technology bracket, and the 2000s are just far too big for most applications.
Defending the DW 1200s is a bit off topic when the criticism raised against DWs was specifically against the old side fed shitters.
  • 1 year later...
REVIVAL OF AN OLD THREAD!
Is anyone running the 950cc injectors? I asked my tuner today just waiting for a response.
Has anyone had any experience with these since this thread last died off?
side feed or top feed?
Sorry!
Side feed - I'm trying for the stock look with ease of installation.
don't do it, you'll want to stab yourself in the eye afterwards.
Just go top feed, 1/2 height ones fit under the plenum nicely and you can get all black fittings rail etc.
I can appreciate that top feed are good and all but I don't want to have to hand the tuner a kit and say "Here you go, piece it together for me" I'm just worried something could go wrong (I guess most tuners should be capable though?)
11mm rail with adapters?
Fake Sard reg?
There are better ways to convert to top feed using a 14mm rail and shorter half height injectors. ;)
Fake Sard reg?
Scott, I'll message you later tonight to discuss if you have some free time.
Fake Sard reg?
lol what a hater, I gave you measurements for nothing :)
I use a Turbosmart FPR1200 anyhow. Got that Sard FPR free so I used it.
Its very easy 14mm aeroflow rail with short spacers, 1/2 height xspurt injectors, reg, few fittings and hose and done. For around the $1000 mark you will have everything you need to drop straight in.
But yeah talk to Scott and he will get you everything you need to drop straight in for good price.
Edited by boostn0199
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
