ok i read the previous thread and since it was 3 years old i would like to know if anyone since then has used one of these valves and any results
for reference, here is the link to the valve:
http://www.spracingonline.com/projects/%E2%80%9Chttp://www.spracingonline.com/store/Sound_Performance_Spool_Valve/3643%E2%80%9D
This is a great concept, but obviously will only work on twin scroll turbo's. Also I imagine this wouldn't work too well if you had a fully divided twin scroll exhaust manifold, as you'd be completely blocking off three of your exhaust runners. If I ever go to a larger (twin scroll) turbo, I'll be looking into getting one of these.
You need an open (non twin scroll) manifold along with a twin scroll turbo.
Mate has one on his supra and swears by it not sure what size turbo it is other than f**king huge precision and it spools by 4000 and pulls right thru to 8500 running 20psi As to where itd spool without it who knows but he is areal happy with it compared to his old t4 setup (yea no real facts in that statement but positive feedback lol)
thats the kind of feedback i was after!
would you be able to find out what manifold he is running and what gate size as well as model of precision?
i would appreciate that info greatly!
that would be a cool comparison to see. But using a twin scroll turbo and normal highmount manifold sounds kind of backwards, you would lose some top end power VS a true TS system. So you would want this 'quick spool' valve to really work down low
I would think this is a rudimentary way of achieving what a VNT turbo is doing.
Ideally would work but would be prone to failures
Seen heaps of YouTube clips of it working
when i looked at these maybe 5 months ago i found allot failures
generally failure occurs were the were the 2 rivets on the flapper mount to the arm
results were comparable to just running a normal twin scroll manifold the quick spool valve had better results on larger turbos 72mm and up from what i found
i have a thread on here floating around some were
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
    • Editting as I hit post to soon, and this will lock out otherwise.
