ok i read the previous thread and since it was 3 years old i would like to know if anyone since then has used one of these valves and any results
for reference, here is the link to the valve:
http://www.spracingonline.com/projects/%E2%80%9Chttp://www.spracingonline.com/store/Sound_Performance_Spool_Valve/3643%E2%80%9D
This is a great concept, but obviously will only work on twin scroll turbo's. Also I imagine this wouldn't work too well if you had a fully divided twin scroll exhaust manifold, as you'd be completely blocking off three of your exhaust runners. If I ever go to a larger (twin scroll) turbo, I'll be looking into getting one of these.
You need an open (non twin scroll) manifold along with a twin scroll turbo.
Mate has one on his supra and swears by it not sure what size turbo it is other than f**king huge precision and it spools by 4000 and pulls right thru to 8500 running 20psi As to where itd spool without it who knows but he is areal happy with it compared to his old t4 setup (yea no real facts in that statement but positive feedback lol)
thats the kind of feedback i was after!
would you be able to find out what manifold he is running and what gate size as well as model of precision?
i would appreciate that info greatly!
that would be a cool comparison to see. But using a twin scroll turbo and normal highmount manifold sounds kind of backwards, you would lose some top end power VS a true TS system. So you would want this 'quick spool' valve to really work down low
I would think this is a rudimentary way of achieving what a VNT turbo is doing.
Ideally would work but would be prone to failures
Seen heaps of YouTube clips of it working
when i looked at these maybe 5 months ago i found allot failures
generally failure occurs were the were the 2 rivets on the flapper mount to the arm
results were comparable to just running a normal twin scroll manifold the quick spool valve had better results on larger turbos 72mm and up from what i found
i have a thread on here floating around some were
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
