so my skyline is sounding like a wrx, ive already researched on the topic and ive so far replaced the coil packs with brand new yellow jacket ones and new spark plugs, when the car is cold started it sounds normal but after a few minutes of driving the sound appears, it used to appear and leave whilst driving but recently it doesnt leave at all and just continues until the car is turned off and on again, any suggestions??
https://www.sau.com.au/forums/topic/447055-rb20-skyline-sounds-like-a-wrx/
also a while back when replacing the injector seals i found out one of my injectors wasnt working 100% but didnt change it at the time, could this be a cause?
Are you seriously asking that?
Yes. No shit an injector not working correctly will cause a misfire. What do you think it would do?
well it worked absolutely fine for the next couple months so i didnt think much of it, im obviously asking a question because i dont know the answer you f**kwit.
Don't get upset.
You brought it up that an injector wasn't working correctly. Of course that will cause a misfire. Fix it. Or alternatively waste your time wondering what else could cause a misfire.
im not getting upset, you were acting like a dick so i responded, from the research i did everyone said coils/plugs and since i had fixed both i was wondering what else would be the problem so i asked, i did plan on upgrading injectors anyway so its not like im going to leave it, cheapest (new) ones seem to be bosch and i'll probably go 440cc since i dont plan on running big power or anything but i do plan on getting some more power out of it.
Ben, this is a forum for people to ask questions, not everybody me included know everything and find it hard to chase down issues. our engines do have common faults but these can be a miriad of things quite often. you do have a habit of beliteling people for asking.
if it frustrates you to be asked then just close the page.
I have had a similar fuel related issue which turned out to be dropping rail preasure from my pump but it did not result in dropping a cylinder but an injector may cause this. my issue for the wxr ayptom like everyone else was a coilpack problem which you have addressed. the next obvious place would be the injector if you know if dodgey but being a mechanical/electrical/fuel componant can bring with it all sorts of fun. it could come down to grounding. best thing is to do some more testing and narrowing down. the easiest way to be sure its not the issue is swap it out but yes this takes spending and possibly thorwing away some cash.
Ok here are more things that can cause a misfire, aside from the coils and plugs
Injectors
Injector loom
Coil pack loom
Various plugs (dirty, wet, not plugged in fully)
Ecu connection
Afm
Vacuum leak
Boost leak
Damaged valve
Blown head gasket
Low compression
Damaged piston
Fault cas
Incorrect timing
Fuel pump
Fuel pressure
Wrong injectors
Etc
So as you can see sorting out the injector issue you have noticed is the sensible first step.
What ecu do you have?
Do you realise you will need and tune for the car to run with those injectors?
stock ecu and yes i know that, spoken to tuners and i had already planned on getting injectors, fuel pump and dump pipe (mines standard but the rest of the exhaust is 3") and putting the boost up to 14psi with a nistune
would putting it on the dyno be a faster way of diagnosing the problem? while talking to the tuners they said its $100 for an hour of dyno time so im thinking of just doing that to diagnose the problem to save the headache of narrowing down the problem and possibly wasting money replacing things which dont need to be replaced
I don't think so.
If you are planning on getting the bigger injectors and a tune just do that.
An easy way is to pul the plug on an injector with the car running. If it gets worse that injector is probably ok. If it stays the same that injector isn't working. Same with coils, but they tend to not cause issues at idle untill they are totally rooted.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
    • Don't use "gasless MIG" (FCAW) you want to use proper MIG. FCAW burns a few hundred degrees hotter than MIG will for mild steel. It is a true ball ache for sheet metal. New MIG / TIG machines even have features like "Spot Weld" as well as "Automatic" settings. Plenty of people say for DIY home hobby, the auto machines are pretty good for 95% of welding. I personally, I'm a sucker for punishment and wanting to dial it in, and be able to adjust the machine. Mainly because I used to MIG weld for a living, and being able to tweak and tune things ever so slightly was my preference. Hence when I bought my ACDC TIG, it has all the adjustments for everything and no "easy" mode. Ha ha I have stick, MIG, "gaslessMIG" and ACDC TIG at home. Out of them, if you're doing mild steel sheet metal repair, and want to do mild steel exhausts, go MIG. If you're thinking you'll want to get into doing some aluminium stuff, or stainless steel, get an ACDC TIG with HF start. If you can, get one with a foot pedal too. My MIG machine is a UniMIG, and my Stick/TIG is CigWeld. If I were buying another machine, I'd buy another CIGWeld. Lots of people having issues with UniMIG, and them not wanting to cover warranty. Everything has to go back to UNIMig themselves. CIGWeld, I've had to use their warranty on my machine for a gas leak, they have repair centres everywhere, (contracted authorised repair centres). First repair place I used were hopeless, but the second place were amazing. Warranty process itself super easy, and second repair place was telling me CigWeld actually cover in their warranty, upto an hour of techs time to help you with your machine, and going through the settings and helping teach you the machine. UniMIG keep trying to get out of replacing motherboards on 12 month old machines.   TLDR, mild steel sheet welding, buy a MIG. my vote is CigWeld for brand.
    • I guess that's what happens when someone can't convert metric to freedom units to machine something. 😛
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
