Hi guys, ive just done a ls1 coil conversion on my s2 rb25. I does idle alot smoother and dirves almost like new, however there is still a slight miss around 4500 then accelerates then misses again at random after that till redline. My fuel pump isnt the issue an im running afr of around 10 to 11 at wot. Following mods are 3 inch dump and exhaust, fmic with 300zx plumb back bov, stock ecu turbo and injectors and a greddy style forward facing plenum, running 6psi as anymore and the missfire becomes more violent. Ive checked for leaks/holes in the pipes and silicon connectors but nothing found. Im lead to believe it maybe my cas?
Edited by hairdryer33
You have to increase the dwell or they will miss.
I have them on my car, with stock dwell they would miss, once dwell is raised, max 5 ms, all good.
Edit. Just read you are using stock ecu. So you can't raise the dwell. So that sucks.
Edited by Ben C34
Good idea, I assumed from what ive read lsx series coil packs are the bomb so just left it. Was running .8 but now around 1mm as I thought it wouldn't hurt. I'll regap tomorrow and let you know how I go. Im on the hunt for a power fc now. The car has come along way, it all started when a dirty old vr commy kept up with me lol cooler full of oil and exhaust leaks didnt help along with dirty afm and restrictive pod (supercheap special now running hks 'shroom)
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
