ok i have two things i need advise on.
1. i have some dodgy pedders reconditioned shock absorbers which are leaking(springs are fine) what should i do/buy?
2. does anyone know if this camber sounds right for a r33gts
rear -1.50 -2.43
front -1.39 -1.20
those figures dont look correct to me.(especialy the 2.43)
thanks
James.
https://www.sau.com.au/forums/topic/44711-advice-please/
Go to whitelines website, ( www.whiteline.com.au ) has lots of info...
shocks... depends what you wanna spend, what you wanna do - once again check whitelines stuff out (they use bilsten shocks afaik)
camber at the rear is a bit much i think, you would definatly want it same both sides, generally -1 on the rears is the go and about -1.5 on the front (this is on GTR, assuming same for gts)
its on the whiteline page :D go to "your car" and pick your car :(
https://www.sau.com.au/forums/topic/44711-advice-please/#findComment-913433
go and see a good mate of many here @ SAU...
Chris @ Centreline suspension
Lipton Drive, Thomastown
He'll set-up your car however you want it :D
And you wont have a problem, he setup my car like a dream
Just tell him Ash sent ya, and that your from Sky's Aust.
https://www.sau.com.au/forums/topic/44711-advice-please/#findComment-913507
