It isn't many bolts, but you would need a crane. The engine is too heavy to just lift out. :P
Personally I would unbolt the gearbox first, just to make it easier. If you are doing it on stands you will need to pull both engine and box together. ;)
How hard?
Not hard. But depending on what you consider hard?
Have you ever worked on a car before? I assume no because you are asking a simple question. So in this case for you an engine swap will be hard.
Best to pull out box & gearbox in one go - loads easier, and if you're tight remove the A/C compressor and cable tie it aside but leaving all the hoses attached (so you don't need to regas the system), do the same for the power steering pump as well.
Unclip all the sensor plugs, etc..
motor out done.
leave the heater hoses until the engine is on the crane, easier to get to.
Just make sure you take time and don't tell yourself you can just remember where every bolt goes because that will be a headache and a half when the new motor is going in
its taken scotty a month to do mine
It can be done, but... just... gah. Enough little differences in my GT shell that scotty has shown me over the GTT one to make me jump on the 'don't do it' bandwagon.
It is legal to do so, at least in VIC, as I have done it.
You will need to at least have R33 GTST/R32 GTR brakes up front.
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
    • Please noooooooo 😭 As for wrap, no thank you mate, I've seen and used "carbon fibre" wrap before, and for these hard tops, they look soooo good when colour matched Like this >>>
