Anf - the best thing to use is "grease and wax remover" (used to be known as - Prepsol - the painters friend).
Supercheap sell the Septone brand in a spray can which is what I use.
However any Prepsol type product does the job to get rid of the marks left by running rich.
Only takes a minute or less. Spray on and wipe off.
Clear coat safe and all that stuff :yes:
Came home today to find this in the mail. 3 x 6.5in Lake Country pads (you choose which ones you want). Not bad for $54 delivered!
Rating: almost everyone I know stands by these which is why I got them. Hopefully they are better then Menzerna pads I have.
  • 1 month later...
Black wow.
For exterior trims and rubber.
The pre wow gets rid of wax and stuff, annoying that the chunky bits block the spray bottle and you have to open the lid to use it.
The Black wow is very good, instructions say "use one sesame seed size drop" thats a tiny amount, but it goes a long way. Amazing.
Pre wow: 6/10 it works ok but the bottle sux.
Black wow: 9/10 its real good and a tiny bit does heaps.
Edited by D.I.Y. Mik
I need buffing pads that dont sht themselves after 10 minutes.
Are the Lake Country pads velcro like the Menzerna ones?
Better than the Menzerna for strong cutting power...... and turd polishing:
Good for buffing sanding marks out, like after painting and sanding the orange peel out.
And..... A silicone squegee for drying after a wash, i dont have to wring out my chamois once when drying.
I use Menzerna polishes with a MINT PRO RO
Love the Meguiars next gen wash.
Waxes range from Meguiars Gold Class liquid. My wax of choice at the moment. (this on top of the Wolfgang sealant)
Meguiars Next gen 2.0. Its a good wax that has a medium level of filling capacity.
Wolfgang deep gloss paint sealant 3.0 (this stuff lasts months) Easy to apply, easy to remove. Takes 12 hours to cure.
I have tried a whole range of dodo juice waxes, while being nice to use I would say their longevity was not something to praise. I also have a bottle of dodo juice car wash but it falls short to the Meguiars next gen wash.
So many things to list in my arsenal I think would just be overkill. So Ill just post up some pics.
This is with next gen 2.0 wax.
This is with Meguiars gold class applied over wolfgang deep gloss. (Overcast doesnt do it justice) I would say the colour is deeper though.
Here are 2 cars with Wolfgang deep gloss. (I do like using this sealant)
I did a full paint correction on this Silvia.
R35 GTR track/street car.
Contamination removed with Dodo Juice Ferrous Dueller and a 100g clay bar. Personally love the new Gyeon Iron for ferrous metals now.
Three stage machine polish with Menz FG500, PF2500 and SF4000 with orange cutting pad and black finishing pad using a DAS6PRO. Isopropyl alcohol used to clean surface between compounding and polishing.
Paintwork sealed and stacked with Duragloss DG111 and Dodo Juice Purple Haze from memory (I use a few different sealants/wax and this GTR was done a while ago).
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
