Hey guys, just recently bought myself a new set of TE37SL Black Editions in 18 x 9.5 + 22 and was wondering what tyres would fit well on my R34 GT-T. I plan on rolling the guards and most probably removing the inner lining @ the front to reduce chance of scrubbing. Any advice would be much appreciated!
https://www.sau.com.au/forums/topic/447132-tyre-size-for-te37sls/
+29 / +30 offest is ideal for the R34GTT. (in my opinion)
However 7or8mm wont make a difference in your case - A 265 /35/R18 will be fine and the tyre will sit flush with the guard.
on a +29 a 255 sits flush with the rim and guard.
Edit: Sounds like you bought GTR fitment.
8.5" on the front for the GTT
Edited by Sinista32
  • Like 1
I spoke to the owner of this R34 a while ago and understand they are running the same spec wheels I have all round, with rolled guards and removed inner splash guard on the front but I didn't manage to catch the Tyre size :(
Edited by Patski
235/40r18 would be the go, very common size so you'll have many more choices with better prices
plus, as above, 235/35 on a 9.5" rim is a fair stretch
You can check out examples on this website http://www.tyrestretch.com/
Or maybe a 245/35, I see that size every now and again, a friend of mine runs 245/35 on 9" wheels and it sits pretty flat.
  • Like 1
235s are illegal on 9.5 rims. Why on earth would you buy wide wheels and put narrow tyres on? Why don't you think about tyres BEFORE you buy the wheels?
Tyres were taken into consideration before the wheels were purchased. I have been getting different suggestions from various people, all of which mind you, have been very similar. Thought I'd take a punt on here for valid opinions. Didn't think it would make people so mad. Edited by Patski
You can usually look up what the rim size range is acceptable for the tyre manufacturer. EG:
http://www.yokohamatire.com/tires_101/customizing/rim_wheel_width/
The reason people get mad is that Skylines are supposedly about good engineering. Putting a fitment set of tyres/rims on them is seen to be the same as neons.
I'm not racing my Skyline, I should have cleared that up in my OP. Regardless, I'm not trying to stick these wheels on their car. Thank you for the link though mate, I'll check it out.
Lol
You don't have to be racing a car to have a reason to put correct size rims/tyres on a car. You just need to want to not turn a car that handles very well into one that doesn't. (and potentially get a defect in the process)
18x9.5 +22 all round is considered a GTR size but post up your results as it'll be interesting to see how it turns out.
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
