Hi, sorry if this is in the wrong spot or has been covered a million times, I did do a quick search. Where's the best place to tap into for the sender for each one (water temp and oil temp) and also where's the best place to get the positive power from so that they come on with the reds? If there's a thread/FAQ that details this then a libk would be great!
Thanks in advance. :)
Water temp sender goes wherever you want to measure the water temp. In reality there are not that many options, so a lot of people end up fitting an adapter into the top rad hose.
Best place for oil temp sender is in a sandwich plate at the oil filter.
Power? From a fuse in the fuse box. One that comes on with ign.
Edited by GTSBoy
Alright sweet, pretty much figured they were the 2 locations, just heard some one say about using somewhere in the head for water temp.
Will have to look for one that uses ignition, never really looked before so not sure what one.
