Matthew Black Posted August 22, 2014 Share Posted August 22, 2014 Found out why my car was blowing out heeps of white smoke its a r32 with a rb25det every now and again randomly the car would decide to blow out the back extream amouts of smoke like a bush fire behind the car then come good shortly after like it had never happend one weekend I went to go for a drive and 10-20 second after starting the car it was smoking like above^ just befor this i toped up the break fluid like i did every now and again because it looked to have a small leak from the master and I was too slack to fix it. anyway after doing some detective work on the engine thinking it was the turbo or valvestems or head gasket or posibly bottom end i found it to be burning break fluid that it had sucked into the engine via the master/break booster some how and making its way into 3-4-5-6 I have never heard or seen anything like this befor so just seeing if this has happend befor to anyone. because it could have lead to full motor teardown for no reson Link to comment https://www.sau.com.au/forums/topic/447145-found-out-why-my-car-was-blowing-out-heeps-of-white-smoke/ Share on other sites More sharing options...
GTSBoy Posted August 22, 2014 Share Posted August 22, 2014 Yuh, hydraulic fluid from brakes or auto trans has sucked a few people in over the years. Link to comment https://www.sau.com.au/forums/topic/447145-found-out-why-my-car-was-blowing-out-heeps-of-white-smoke/#findComment-7371871 Share on other sites More sharing options...
Matthew Black Posted August 22, 2014 Author Share Posted August 22, 2014 that spun me out biggest clue was the smoke dident smell like burning oil just looked like it 1 Link to comment https://www.sau.com.au/forums/topic/447145-found-out-why-my-car-was-blowing-out-heeps-of-white-smoke/#findComment-7371896 Share on other sites More sharing options...
Blackkers Posted August 22, 2014 Share Posted August 22, 2014 So what was broken? There's a one way valve from factory in the brake booster line, I think GTRs are the only other model with a clutch booster Link to comment https://www.sau.com.au/forums/topic/447145-found-out-why-my-car-was-blowing-out-heeps-of-white-smoke/#findComment-7371976 Share on other sites More sharing options...
jiffo Posted August 22, 2014 Share Posted August 22, 2014 Yes, doesn't smell right and would have caught out a few. Cars are getting on, 25 years service is a big ask and owners would be advised to think about replacing vital items like brake boosters, hydraulic hoses etc. The metal style can be serviced, not so the more modern plastic stuff. Another one is the fuel reg. When the old diaphragm starts to leak, all sorts of dreadful fuel economy and general running issues. Link to comment https://www.sau.com.au/forums/topic/447145-found-out-why-my-car-was-blowing-out-heeps-of-white-smoke/#findComment-7372029 Share on other sites More sharing options...
Matthew Black Posted August 23, 2014 Author Share Posted August 23, 2014 So what was broken? There's a one way valve from factory in the brake booster line, I think GTRs are the only other model with a clutch booster i think the break fluid ate it way into the diafram in the booster maybe Link to comment https://www.sau.com.au/forums/topic/447145-found-out-why-my-car-was-blowing-out-heeps-of-white-smoke/#findComment-7372139 Share on other sites More sharing options...
