Hey all,
I finally got my R34 today after a long 5 month wait for compliancing etc. Let me just say it was DEFINITELY worth the wait! The kit looks so sweet, and she's in perfect condition. I haven't given it a hard go yet, but it's definitely not sluggish :D
I'll post some pics tomorrow when I get the digi out.
Just a question though, I always thought that Xenon lights were Halogens (the bluey tint lights). For some reason mine have no blue in them?
Cheers people :(
https://www.sau.com.au/forums/topic/44715-she-has-arrived/
Don't tell me you wanted the car because of the blue lights, it's just the frequency or temperature of light....4500-5000K will get you the blue tint from HID.
Xenon is a brand name...they rip the HID guts out and replace with crappy halogen :)
Also...is Xenon is a brand name???
Xenon is the gas they use to get the blue light which also gives them that directive narrow band of light...
https://www.sau.com.au/forums/topic/44715-she-has-arrived/#findComment-913882
I never suggested that's why I wanted the car. I was just wondering why they weren't blue. Any way of changing the frequency as u said?
Just having a dig at you mate :)
No you can't change the frequency via any means such as voltage. It's the bulb itself, buy ones with 5000K or higher, going into the blue temperature range.
edit: here is Kelvin colour temperature scale for your reference as you can see where blue light starts.
https://www.sau.com.au/forums/topic/44715-she-has-arrived/#findComment-913980
I don't think I'll bother changing them. They are quite alright as is.
I agree it all depends on the person, if it does the job leave it. Personally after changing from PIAA Xtreme White (4150K) to PIAA Super Plasma blubs 5000K Low Beam, 3800K High Beam. I probably go back to the Xtreme white, I find the blue strains my eyes and if you have tinted windows you may find it more difficult depending...thus why we have HID kit.
https://www.sau.com.au/forums/topic/44715-she-has-arrived/#findComment-914470
Pics will be up tomorrow.
It's so etch though, the very day I get my new car (and just a few weeks after getting my license), a group of girls I know, in exactly the same boat as me (ie. new car, new license) are in a horrific car crash in which the car flipped one of them died. I hadn't met the girl who was killed, but one of the girls I'm really really good friends with is in intensive care (she had a blood clot in the brain, but should recover - we're hoping she wasn't brain damaged).
Just proves that speed limits exist for a reason, and that you have to be bloody carefull as a new driver! Really put a dampner on getting a new car, especially after seeing the crash scene :|
https://www.sau.com.au/forums/topic/44715-she-has-arrived/#findComment-915175
Ok finally got some pics. I'll take some more tomorrow with my digi cam. These were taken on my mates camera today whilst the car was wedged in the garage (so you couldnt really get any good shots)
Tomorrow we're going to take some pics of all our cars around the harbour (I know it's a bit cliched, but oh well), and I'll also get some of it in the underground parking area of my apartments (so I'll be able to get some nice side on shots)
Anyway here they are:
https://www.sau.com.au/forums/topic/44715-she-has-arrived/#findComment-915572
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
