OK, I had the idler bolt snap on my Rb25det Neo, which threw the cam belt on the free way at 110kph. As a result, both sets on valves are bent. yes all 24.
So engine is in bits, and valves are out, but here it is...... Where can I find replacement valves other than Nissan. The place where the head is cant source them, and well the ***** on ebay say they can get them, but that was over 2 weeks ago. They arn't the same as a normal rb25det, as mine is a NEO, they seem to be a different size to others.
Is this normal?
Inlet About 104mm head 30.4mm tip 6mm shaft dia 6mm all approx. as I don't have verner
exhaust about 98mm head 29mm tip 4mm shaft dia 6mm
Nissan want, inlet $35 ea exhaust $59 ea
With all the rb's out there, there must be someone who does them cheaper the nissan
Need help pls
Edited by Daffy
https://www.sau.com.au/forums/topic/447150-valves/
Erics performance parts in the US sold me valve guides at a good price. They have a fair bit of stuff. Cant say I ever looked at valves but worth a try
As suggested though, getting a second hand head and robbing them out of there would be cheapest
https://www.sau.com.au/forums/topic/447150-valves/#findComment-7372020
Yer I been looking for a 2nd head, but no one has 1, or wants to part with it cheap or wants the same price as the valves....
The normal rb25 heads are different to the NEO. The only thing that might fit on the both of them is the exhaust manifold. Rest of hardware would have to be changed.
I bought the ones from ebay over 2 weeks ago, and they are having "problems from there supplier" getting them. Now Im in a dispute trying to get my money back and got to look else ware. i got to wait for money to get back before I can buy new ones atm.
Is there a link to Amayama Wolverine so I can check that out?
https://www.sau.com.au/forums/topic/447150-valves/#findComment-7372177
amayama.com or just call kudosmotorsport and ask Andrew for a price. I would try Andrew first as his communication is so much better but both should be able to come through with the goods in around 2 weeks.
Also here is a link to amayama http://nissan.epc-data.com/skyline/er34/3953-rb25det/engine/130/
https://www.sau.com.au/forums/topic/447150-valves/#findComment-7372310
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
