My video from yesterday,
Nice video & commentary,
and you just had to be there to record that one time where I went too tight on Hungry.
Not sure if sarcasm or serious,
but I believe the S15 has Kings Real Lows on (and maybe that is all :/).
and yeah, only 184rwkw (cold air box, RB25 turbo @10psi, FMIC with water injection and turbo back exhaust).
The S15 is quicker than my R33 was, but I miss the sound of my R33. :ermm:
I'm also uploading my crap iphone video and photos, should be ready in the morning :)
https://picasaweb.google.com/101444716046776616715/SAUQLDLakesideRacewayHappyLaps2014Oct
- Link to my pictures.
They're only iPhone pictures (stupidly forgot the DSLR), but I figure something is better than nothing.
And same with my video from the iPhone,
  • Like 1
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
