Hi guys,
I have 94 32 GTR. My gears feels very crunchy especially when it's cold. Takes around 50ks to be ok.1st gear is very hard to put in. It has a short shifter put in it. Not sure if it's masking the syncros. Doesn't feel smooth at all. Very stiff n rigid. It's crunchy when put into 1st,then changing into 2nd, 3rd, 4th and 5th. But the crunch is worse at 1st,2nd and 3rd. I need advice. Pls help.
Thanks.
Sent from my iPhone using SAU Community
As Nizmo said maybe start budgeting for a GB rebuild.
Check your gear shifter bush (standard is white plastic washer at the end of your gear stick)
Change your GB oil and I'd suggest going a stock Shift stick.
(under $100 new, a lot less for 2nd hand).
32's are also known for being more difficult to get into gear when the GB is older and cold
Short shifters are naturally harder to get into gear so this just exasperates your issue
Edited by Sinista32
-> mashing the Syncro's on your gearset <-
now take time to warm it up and change slower. take the advice above
save up to put something like an OS gieken gearset into it.
Unless your a racecar driver or got money to throw at something better that is !
It's a 32GTR and the gearbox / syncros are the worst of the bunch and they're OLD
Thx guys! I might go back to a normal shifter and prob change the bushing too. Is there anything else u guys reckon I shd change jus to keep it going? Not exactly the rite financial time to get another box.
The synchros are worn down too far to allow the gear to slow down enough to engage. Hence why its crunching
Just baby it or try double clutching until you can afford a 2nd hand box or rebuild
    • Ahhh, that, yeah, but it all worked out well in the end As for the ITB noises, I don't really wind it out with her in the car, and the dort only really starts dorting hard when your WOT or up it hard
    • It wasn't about the dollars. I mean how she didn't like the loud exhaust and you had to change it again 馃槢
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
