Hi
I have recently bought A 370GT P Coupe Auto.
Driving up Henri Robert's Drive Tambourine Mountain in the rain ,steep and windy, the slip light is on most of the time regardless of how smooth or slowly I drive. Doesn't inspire confidence
It is fitted with YOKOHAMA Earth 1 tyres in as new condition.
Can anyone recommend a good wet weather tyre that they have actually used.
I have asked this before but was unable to get a reply.
What does the 370GT P have in the way of traction control and what does the SNOW switch do
I bought a work shop manual ,DVD, and can't find any reference to TC or the SNOW facility
Cheers
Steven
Are front and rear tyres the same rolling diameter?
That will cause issues with traction control of they aren't.
I already told you about snow mode, it takes off in second gear. And it has traction control. What more do you want to know?
As Ben says, if you've got tyres that mis-matched in terms of rolling diameter it will cause issues.
I had 225/45/18 and 265/35/18 combo and at the slightest drop of the clutch the TCS would kick in - actually it was a little dangerous as if you had to merge into traffic it would cut the power!
When the fronts needed new tyres I went to a 225/40/18 and its much happier now, you really have to drive quite hard to get the TCS working, its made it all much happier
If the tyres are the same all round (or the very similar rolling diameter) and you have issues then I'd be looking at the sensors
With the utmost respect Ben I am not sure if that is correct, if it were a manual car how would it take of in 2nd gear and with the Snow switch on it will easily chirp the tyres, in second Gear!
Regards
Steven
ps
I am not looking for an argument simple trying to understand what is happening
Regards
Steven
ps
What? It's not a manual. It's an auto.
I would think if it was a manual, it wouldn't have a 'snow' button..
I would expect they would all have at least TC.. if also it has VDC, it will have a VDC off button somewhere.
Try these...
See if they help..
2008-infiniti-g37- VDC.pdf 2008-infiniti-g37-om snow.pdf
When I first got my V36, I also found it slippery, but that was the tyre release agent. Once that was gone, all good. I now only get the slip light when I deserve it.. :whistling:
The extremely easy way to see what happens when you engage Snow Mode is to do it. Then you wil understand in 30 seconds what it does. And of course manuals don't have a 'transmission mode' button lol.
But yes I completely agree with the guys above - I am willing to bet you have mismatched tyres either front to back or side to side.
  • Like 1
No problems.
I have Nitto Motivo 245/45/18 both front and rear, replacing the 225/50/18 front and 245/45/18 rear Chinese compliance tyres. Cannot remember the brand...
225/50/18 does not fit properly on an 8.5 inch rim, as per rear of V36. Generally 8.0 is the widest wheel that would take that size comforably, unless you are going for a streached look... either way that would partially explain a wobbly rear end...
In addition the Yokaham Earth range of tyres are hippy hippy baloney greeny tyres that are optimised for fuel consumption, not grip. They also are not available bigger than 16" for AUS market,
I think what you have are the BluEarthA which is a JDM tyre, still not approved for 8.5" wheel..
I would change the tyres as a good starting point for sorting out these issues. Get with a quality set of 245/45/18 front and rear... A lot less coin and hassle than finding the wierdo 225/50/18 fronts..
Also consider that if your rear tyres (that are fyi significantly too narrow for even stock power levels) are actually JDM and not Australian DOT approved, if you have an accident, your insurance will NOT cover you whatsoever, as any JDM/non-DOT-approved tyres are illegal for use on Australian roads. Just something to note.
  • Like 1
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
