My thoughts...
http://www.skylinesaustralia.com/forums/sh...hlight=manifold
I think part of the reason i and others have noticed an increase in throttle response with aftermarket manifolds is that we usually bolt on different turbos at the same time, typically with freer flowing turbines and exhaust housing..so perhaps is a gas flow/turbine/exhaust housing as much as manfiold design thing
...i really need to get out more...since moving to Melb my post no. has probably doubled
I have one that is exacly the same but not from him and it revs more freely and sounds more meaty.I have'nt got it dynoed tuned yet so I'll keep u posted.Plus I have a larger turbo and bigger cooler and piping so it could be better coz of all that?
The design looks very similar to the trust manifold.
Just a word of caution - manifolds aren't manifolds. I know a guy who changed his tubular manifold for one with pipes 2mm larger and the result was an increase in lag and drop in response. Only 2mm difference. This was on an SR20.
Freebaggin fitted a tubular manifold recently (not sure what style/design), combined with a GT30 only to find no gain in power or response at all.
Having said that, for $490 its pretty bloody cheap - and if nothing else, it will give the car a pretty tough note:)
Oh well, sorry Roy, if you havent seen it, I must be wrong - fair call, no more replies from me.
uh - oh, ive upset somebody. :Oops:
Come on Steve....just wondering if there is a Trust low mount manifold as i have never seen one for an RB series engine.... wasnt having a dig or trying to be short....like i said "as far as i know"..... :P
If it is modelled on a Trust manifold , or Blitz, Apexi, HKS (any jap brand) then id change my thinking as im only going on crap i have read and observed when working with some material handling/fluids software...hardly automotive performance technology, so practical results speak volumes more then casual observations and texts :Oops:
Id love to know if others like the GT30 example you have mentioned had similar experiences, as i bolted the new turbo and manifold on at the same time , so i dont know what should take credit for the nicer off boost response, if a bigger turbo would work just as well with the std manifold...well i would rather a cast jobbie over a thin walled tubular
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
