I am doing another turbo conversion and E85 and possible cams
It will put me past the 300 rwkw mark. Will the gar box be able to handle it.
Or will i need to change it out to a 350z gearbox. I have done a heavy duty clutch 3 months ago
also a cuso 1.5 way diff will be in soon too.
Cheers for any info
https://www.sau.com.au/forums/topic/447244-r34-gtt-gearbox/
For the street it will be fine. Depending on the exact clutch, that will be the first thing to go. I suggest putting up the clutch brand and model so we can tell you if it is up to the task. If you are doing heavy Motorsport it may not be good enough. Simon s14 broke third gear multiple times in his drift car but like I said he was pushing 350 and it was Motorsport only. TLDR for street it will be fine.
https://www.sau.com.au/forums/topic/447244-r34-gtt-gearbox/#findComment-7373628
Plenty of R33's and R34's running ~300rwkw with stock manual gearboxes on the street, shouldn't be a problem. Autos start dying a lot earlier.
Obviously if you have a HD clutch, aftermarket diff and wide sticky rubber there will be a lot more load on the box ... the weakest part of the driveline will give up the ghost first, not surprisingly.
https://www.sau.com.au/forums/topic/447244-r34-gtt-gearbox/#findComment-7373686
The gearboxes are strong enough to hold 300kw no worries, mine held 390kw for quite a while but fatigue and motorsport killed 3rd gear...
It depends on how you drive it and what condition it is in... I put a low km 2nd hand box in and have done 2 full track days since with no signs of weakness.
Clutch depends on what you are going to use the car for, Race Clutch, NPC, Nismo... Plenty of choices!
https://www.sau.com.au/forums/topic/447244-r34-gtt-gearbox/#findComment-7374269
  • 5 weeks later...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
