Bar fits completely fine.
Purchased it brand new from Nissan with a brand new N1 reo to go with it.
Fitted it all up with no issues whatsoever, other than the usual 12mm overhang on the guard area which honestly doesn't bother me.
The reason for the purchase in the first place was due to my other bar being damaged from the driver's side headlight area being hit lightly, resulting in a smashed headlight and cracked bumper. The reo was also damaged heavily in the process.
Here's a photo of the passenger side which fits near perfectly and it looks like it's meant for the car out of the box.
The driver's side is another story entirely, largely due to what was explained above (I suspect!)
Can anyone give me tips on how I can raise the bar on the driver's side? :\
http://i.imgur.com/Vj1L3TJ.jpg
http://i.imgur.com/s3oAT9K.jpg
http://i.imgur.com/cvvgEsg.jpg
Any advice is appreciated.
Have you tried backing off and then adjusting the reo at all? Did the headlight bolt up okay? Rad support isn't a bit out?
I thought the reo could only be adjusted horizontally via elongating the preexisting holes and not vertically?
It bolted up okay-ish, the bracket that is hidden by the indicator where the 2 headlight bolts sit was almost certainly smashed in when the other damage was caused however - I figured this could play a part in it, but needed a second opinion as I believe the issue lies elsewhere.
I'll check the rad support tomorrow - how big of an issue is this, assuming it's the problem? Am I going to need a new one or have to remove my entire front end including rad/horn/misc to fix it? ;_;
Sorry, I didn't intend to raise any alarm bells, it may not be that bad. It might just require a bit of patience to get right. Assuming the bonnet and guards haven't been removed, how are the panel gaps between both sides, pretty equal? It's a bit hard to judge from the photos, but it does appear as though the drivers headlight is sitting 'in' a bit more than the passengers. Try and loosen the all mountings and see if you can't readjust them at all.
It's definitely the bar/reo. I straightened the headlight up because it wasn't properly bolted in when I first installed it but there's still a huge gap.
Here are some more photos for reference.
http://i.imgur.com/7JjGNV7.jpg
http://i.imgur.com/haqQWXm.jpg
http://i.imgur.com/WSS7LVV.jpg
http://i.imgur.com/SivDe52.jpg
http://i.imgur.com/gV3EImg.jpg
Hopefully that gives you a better idea.
Another mate of mine recommended unbolting the Reo on the driver's side and having someone pull it up, then tightening the bolt while they're holding it up slightly - trying that tomorrow!
Edited by Cevzy
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
    • Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
